12-05-2020
09:05
16:17
12-05-2020
09:05
16:17
I was taking my Fitbit Charge 4 off one day and the Band Holder broke off. I don't know if it is even possible to fix. I only have two pieces and after watching YouTube my spring is gone. One of the screw holes has a screw in it. How am I to fix this. My Fitbit was purchased in April 2020 and the website says there is no warranty when I tried to file a claim. Now I am back to my Fitbit Charge 2 which seems to be build better than the 4.
Can anyone help me?
Moderator edit: format.
08-29-2022 03:18
08-29-2022 03:18
I have the exact same issue. Customer support said "sorry, out of warranty. bad luck, now go buy a new one"
Best Answer08-29-2022 03:30
08-29-2022 03:30
08-29-2022 04:18
08-29-2022 04:18
I bought one of those bands and, yes - it works. BUT, because of where the band attachment part broke off, note that your device may no longer be watertight, and water can get in where the screws are and fry your charge. Ask me how I know … 🙁
08-29-2022 04:27
08-29-2022 04:27
Best Answer08-29-2022 09:06
08-29-2022 09:06
Best Answer08-29-2022 14:52
08-29-2022 14:52
Best Answer08-30-2022 10:19
08-30-2022 10:19
This just happened to me 2 days ago. The band holder did not fully come off yet, it's halfway off but the screws are still in place. I received this as a gift in Feb 2021 so I assume I am out of warranty. Can I try to glue it back into place?
Best Answer08-30-2022 11:57
08-30-2022 11:57
Best Answer08-30-2022 14:22
08-30-2022 14:22
Best Answer09-12-2022 18:52
09-12-2022 18:52
Best Answer09-15-2022 02:14
09-15-2022 02:14
I've replaced my strap several times since I've had it (over two years), but recently the strap has started to come off several times a day, uncoupling at the connection. Even when I changed for another new one. It ony take a slight knock or putting an arm through a sleeve for it to come off. Does this mean that the main connection is now probably faulty rather than the strap? I assume this would mean a complete replacement now?
09-15-2022 13:21
09-15-2022 13:21
Are there any bands that people have found that don't require the clips? Mine have broken and are out of warranty. 😕
09-15-2022 19:17 - edited 09-18-2022 18:18
Hi everyone! Thank you for sharing your experiences and tips and for your feedback
@Madasahatta @Jones1265 , Nice to see you around. I merged your posts here as the topic is being discussed here! Please have a look what other users have suggested. Or get in contact with our Support team if you haven't done so.
See you around.
09-15-2022 20:04
09-15-2022 20:04
As many many Charge 4 customers have posted one of my band's connectors broke. I was offered a lousy discount as compensation.
I am a long time Fitbit user but won't be no longer. I feel used and ripped off.
09-15-2022 20:49
09-15-2022 20:49
@TAJ7 your post was moved to this thread where others are discussing the same topic. See what they are saying and their solutions.
09-16-2022 05:57
09-16-2022 05:57
Odyssey13,
Still feeling used and ripped off. Now you have insulted me.
Moving me to a thread with the statements I should "see what they are saying andbsee what thier solution is" insulting.
I know what they are saying, we feeling used and ripped off, and the solution is not for the customers to solve but the company that intentionally sells a defective product and then refuses to fix the problem.
10-31-2022 09:18 - edited 10-31-2022 09:22
@DavideFitbit Hi. I have the same problem with my Fitbit charge 4. Can you help me get it fixed? I am located in Romania, East Europe. Thank you!🙂
It was purchased in at the end of February or March this year.
Best Answer10-31-2022 12:57
10-31-2022 12:57
Best Answer10-31-2022 17:41
10-31-2022 17:41
Best Answer11-16-2022 09:34
11-16-2022 09:34
I had the same problem. Connect6or for the strap spontaneously broke off my Charge 4 tracker. Good news: I was successful in a repair. Search for "Broken strap connector: Successfully repaired! DIY"
