03-02-2023
18:58
16:20
ManuFitbit
03-02-2023
18:58
16:20
ManuFitbit
This is because the clip on the body of the tracker has broken. This is a fatal flaw with the Charge 4 and FitBit shrugs it off with claims that the tracker is out of warranty. I have been extremely disappointed in that business practice and it concerns me about purchasing any other FitBit product.
so what I have done is duck tape the bands onto the body of the tracker. I remove tape to recharge. When bands cracked, I purchased an inexpensive replacement off of Amazon. This has now worked for me for over a year. While certainly not optimal, it has helped me figure out what should be my next tracker purchase. I want to make sure that whatever I buy is worth the high price of these systems.
Moderator edit format and label.
03-17-2023 10:17
03-17-2023 10:17
I have the same issue. Charge 4 is past warranty, and I did not get any help from customer service. Explained my issue, was told to send pictures, then told an email will be sent. Customer service rep then told me to end the chat. Very disappointing. Thinking about buying a Garmin.
03-20-2023 15:10
03-20-2023 15:10
I had the same problem. I ended up actually using crazy glue to keep the strap on. At this point my battery isn't holding a charge any longer anyway so it doesn't matter if the strap in on there permanently anymore. My Charge 4 isn't even 2 years old yet. Extremely disappointed in the product and no help from customer service. Will not purchase fitbit in future.
03-20-2023 15:25
03-20-2023 15:25
I hope the Fitbit leadership is reading these texts. They are creating poor will among their customer base!
03-23-2023
16:30
04:04
03-23-2023
16:30
04:04
Hi @CliffyCat, @SunsetRunner and @JPE3914. Welcome to the Fitbit Community.
Thanks for the feedback regarding Charge 4 band.
If you are still experiencing this, please contact our Support Team.
03-23-2023 16:38
03-23-2023 16:38
03-26-2023 19:58
03-26-2023 19:58
This same thing happened with my fitbit as well. It's only been 18 months and a piece on the tracker that holds the band in place broke so I can no longer wear the fitbit. A clear design flaw if this is happening repeatedly. I would not want to buy this product again knowing that I spent all that money and it will just fall apart so quickly from normal use.
