05-30-2023
20:31
09:59
ManuFitbit
05-30-2023
20:31
09:59
ManuFitbit
A year ago the unit broke where you attach the bracelet, it wasnt the bracelet.
Moderator edit: clarified subject.
05-30-2023 20:48
05-30-2023 20:48
Hi @Ebgon If you're under warranty, check with customer support. If not, go to Amazon and buy a protective cover band for the Charge 4. It actually takes the pebble piece and encompasses it, so you don't need the broken bit that the band would usually clip into. You can see these on Amazon and they are under $20, depending on which band you get.
