11-07-2020
13:48
16:17
11-07-2020
13:48
16:17
Weather app not installing although fully latest updated firmware and app
11-08-2020 06:42
11-08-2020 06:42
I'm having the same issue. No gear icon for my weather app. Location services are on.
Best Answer11-08-2020 07:06
11-08-2020 07:06
{SOLVED] Installed now.
Best Answer11-15-2020 18:35
11-15-2020 18:35
Hi, did you solve the problem for the weather app? I am having the same problem now and I'm just purchased.
Thank you in advance. 🙂
Best Answer11-15-2020 19:42
11-15-2020 19:42
11-16-2020
05:42
07:07
11-16-2020
05:42
07:07
Welcome to the Forums, @iitmemecell and @Checkmaggie. @Vickyxie, it's great to see you here.
I understand how are you feeling and appreciate the feedback provided. As you were able to note, Charge 4 requires an update in order to enable the features you are waiting to see. This update should begin to download in the background following setup and should complete within 48 hours. In order to complete the update, please ensure the app is open in the background and regularly syncing.
Let me know if there is anything else we can help you with.
Best Answer12-21-2020 22:46
12-21-2020 22:46
Where do I install this? It's missing from my fit charge 4?
Best Answer12-23-2020 10:11
12-23-2020 10:11
It's great to see you around, @littleangel1977.
To set up the Weather app:
If the weather doesn't update, check the following settings:
If you change locations, sync your device to see your new location in the Weather app.
Let me know the outcome.
Best Answer05-13-2022 08:07
05-13-2022 08:07
Hi Alejandra and Fitbit Community,
I'm having the same issue with my Charge 4. I've made sure Fitbit is allowed to run in the background, that location settings are allowed, and GPS is on. And I've manually synced with the app multiple times. But I still can't access the weather my device. Thank you for any advice!
