Charge 4 clip for pocket
ANSWERED
I am a healthcare worker and therefore bare below the elbows for hand washing. I would like to be able to take the strap off the charge 4 and pop it into a case with a clip to attach to my pocket. Used to squeeze my charge 2 into a zip case but this is bigger. Any advise?
1 BEST ANSWER
Accepted Solutions
Hi, Amazon now has a clip holder for the Charge 3 or 4 similar to the One and Inspire. It is working out great for me.
EEweca 2-Pack Clip Holder for Fitbit Charge 3/4 Silicone Case Accessory, Black+Storm Blue
4 REPLIES 4
Hi @Lacrig  several members have had similar problems. A while back, a guy posted that he bought a cigarette lighter holder with a clip and it fit the Blaze pebble. I did a search on Amazon and found a Zippo lighter pouch with clip that might work for you. You should see what they have and let us know what you get. Thanks for being out there and taking care of others during this time of the virus. I can't imagine how often you're washing your hands. Be safe and keep stepping.
Stepping in the U.S.A. since September 2013. Android 14
Where do you wear this clip? I wore the Charge 4 in its clip on my pants pocket and it didn’t register a single step all day. I got the holder because the clamps broke off the body of my Fitbit so it can’t attach to any more watch bands.
I usually wear mine attached to my bra, or attached to the waistband on my pants. I have on occasion placed it in my pants pocket.  I also tested it to see how accurate the step count was and it was off but not by much. I hope this helps.
