02-01-2022
08:53
15:46
02-01-2022
08:53
15:46
Charge 4 display became dull, not seen properly, kindly suggest
02-01-2022
17:48
11:50
02-01-2022
17:48
11:50
@TSR3333 , Nice to see you here! Thank you for your message.
Have you tried restarting your Charge 4?
See you around.
Best Answer02-09-2022 09:45
02-09-2022 09:45
TSR3333,
Sadly quite a few devices are reported as doing this.
I f your in warranty call customer support you should (sadly depending on where you live) get a replacement, don’t wait if it’s in warranty act now!
Best Answer02-09-2022 10:10
02-09-2022 10:10
I had the same issue and Fitbit support solved my problem. I had accidentally turned the sleep mode on. Hold side button down for 4 seconds. Sleep
mode and do not disturb will pop up. Make sure they are turned off. Voila!!
