04-15-2020
10:38
12:05
LizzyFitbit
04-15-2020
10:38
12:05
LizzyFitbit
I was so happy today to receive my brand new Charge 4!
Set-up went smoothly, BUT...I don’t get any notifications... not from calls, texts or apps!😤😭
Is it me or my device? Please help me!
07-12-2020 23:52
07-12-2020 23:52
Take it easy! Maybe it’s only because the DND option is activated. Just keep pressed the side button and turn the DND off. (DND = Do Not Disturb)
Best Answer07-15-2020 11:28
07-15-2020 11:28
Me too
Best Answer07-16-2020 17:54
07-16-2020 17:54
I’ve tried all recommended solutions and I still cannot get my charge 4 to receive notifications. I have an iPhone 11 Pro
Best Answer07-17-2020 06:12
07-17-2020 06:12
that’s not good. If I can’t make it work, I’ll have to return it. 🤷🏽:male_sign:
Best Answer07-17-2020 22:53
07-17-2020 22:53
Spot on! Why would an update turn the DND on?? It all works again so thank you
11:14
17:59
07-21-2020
11:14
17:59
Hi everyone. It's good to see you participating in the forums. I'm sorry for the delayed response.
@Tgreen7, @KrisOTee and @BitAddict, thanks for the information provided as well for your efforts while working on this situation. I see where you're coming from about your notifications not working and just to confirm, have you made sure to set the "Show Previews" to Always for phone, messages, calendar and other apps notifications? If that's correct, make sure the Fitbit app is updated in your iPhone, go to your phone's settings > Messages and toggle the iMessage setting. Then try testing the notifications one more time.
@NLCC and @Eiphnh, thanks for getting back with the requested information. Let me share that our team is aware that some of our members are getting "Notifications service not running" on their Fitbit devices and they're currently working to get it fixed as soon as possible. In the meantime, we recommend to keep your tracker and the Fitbit app updated so you can receive the quickest solution.
@Lejomr, thanks for joining this thread. Since your post didn't mention, I'd recommend to give a try to the troubleshooting tips described in this help article.
@Gurvi, @SunsetRunner and @Neil_nevo, thanks for sharing the steps that worked for you and I'm glad that your Charge 4 is receiving your notifications. Good job!
Let me know how it goes.
07-22-2020 19:51
07-22-2020 19:51
I just bought my charge 4 today. I have tried every recommendation in the thread and cannot get my notifications to come through. All of my settings are correct. My DND is off as well as sleep mode. My app is updated. I tried rebooting my phone and charge 4 per the instructions above and nothing.
I have an iPhone 8 Plus
07-24-2020 12:22
07-24-2020 12:22
The notifications are working now but I don't want my previews to show on my phone. I used to get notifications on my charge 2 without having them preview on my phone. Why doesn't the charge 4 work the same way?
Best Answer08-01-2020 03:46
08-01-2020 03:46
I have an iPhone 8, bought Fitbit charge 4 yesterday. Can’t get text, calls or any notifications to work. Uninstalled several times. Worked fine with my charge 2 previously. Any advice please?
Best Answer08-03-2020 02:56
08-03-2020 02:56
Lizzy, any update on the fix? Thanks
18:19
17:59
08-06-2020
18:19
17:59
Hi @Megan777h and @Jo_C_. Welcome to the Community Forums. @BitAddict, I'm glad to see you here again.
Thanks for your continued reports and feedback about your Charge 4 not receiving notifications. Let me explain that with the introduction of iOS 13, the required settings to receive notifications changed. For that reason, on the Notifications settings in your phone you'll need to set Show Previews to Always or When Unlocked for Fitbit, Phone, Messages, Calendar and any other preferred app. Also, make sure to add a check mark for Notifications Center under Alerts.
I'm sorry for the inconvenience this has caused you. Your feedback won't be taken for granted and will helps us to evaluate our procedures to improve your Fitbit experience.
I'll be around if you have more questions.
08-13-2020 14:04
08-13-2020 14:04
My app also says "notification service not running. A phone restart is required to re-enable notifications on your tracker." I have tried everything. Restarting phone, checking settings on phone, restarting device. Switching on and off Bluetooth. Forgetting device and adding again. Nothing works. Please help. It is very frustrating. Thanks.
Best Answer08-13-2020 14:30
08-13-2020 14:30
I am having the same problems too and I have an inspire. Is there any way to fix this? I went through all the troubleshooting sets and still no notifications.
Best Answer08-15-2020 22:44
08-15-2020 22:44
Best Answer08-22-2020 09:46
08-22-2020 09:46
I just got the 4 because a few days ago Fitbit had an update that made the 3 not work on my phone. I get zero notifications on this 4, not even the step reminder.
Best Answer08-24-2020 11:14
08-24-2020 11:14
My notifications haven't been working since I got the Charge 4. They didn't work on my Charge 3, either. They also didn't work on my wife's Charge 3. And her Charge 4. And her replacement Charge 4. So that's 5 devices so far that at some point stopped receiving notifications. There is always some fix that makes them work briefly (like sometimes for an hour or less), then it's back to no go. It's crazy that this problem has persisted so long.
Anyway, I was able to get mine working again today after noticing that my Charge 4 had DND mode turned on. I think it's been getting turned on accidentally during my workouts (for instance if my Fitbit screen comes into contact with my workout equipment for an extended period of time). Hoping that's it and we're good to go for the time being. It's also worth noting that the automatic Sleep Mode sometimes will not turn itself off after you wake up- that was the source of my issue at some point, too.
Best Answer08-25-2020 10:18
08-25-2020 10:18
I was so excited as I got my charge 4 today and my notifications don’t work either. I should’ve stuck to the Charge 3 which was great. One of the reasons I use a Fitbit is because of the notifications. I’m very disappointed. Fitbit sort it out!
Best Answer08-25-2020 18:21
08-25-2020 18:21
I seem to be having a similar issue. I've had my charge about a month but no notifications just started.
Best Answer08-26-2020 03:59
08-26-2020 03:59
I just bought charge 4 and replace with my charge 2 today.
Phone : iPhone xs
iOS : iOS 13.6.1
Fitbit App verison : 3.28
1.With my charge , when call and message comes, the charge 2 vibrate normally. And text message will show up
2.With Charge 4, when call and message comes, the charge 4 will NOT vibrate. And text message never show up. Notification on Charge 4 is always empty.
I just double check several times with this help article https://help.fitbit.com/articles/en_US/Help_article/1979.htm?Highlight=Not%20vibrate%20call
All setting is correct based on this Q&A. Notification of Charge 4 is still not working.
I also follow @LizzyFitbit comment on this post, still in vain.
I make sure that all notification of prefered app in my iPhone turn on and set as "Show Previews—Always or When Unlocked"
And DND and sleep mode is off.
I contact support center chat, they told me this issue happen on parts of user and dev team is working on it. They tell me to retry when the Fitbit app update in the future.
Notification feature is very important for me, Is there any workaround?
Best Answer08-26-2020 20:27
08-26-2020 20:27
