04-26-2023
19:55
12:26
04-26-2023
19:55
12:26
Suddenly sensors of charge 4 Have stopped working ; the device charge displays syncs all fine but no light on sensor; thus has become a mere watch
04-28-2023 12:31 - edited 01-31-2024 07:20
Hi there, @Suneel_S. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Charge 4.
As @Julia_G and @willjoe have recommended, please try the following steps:
Also, for more detailed information, see: What factors can affect my heart-rate reading on my Fitbit device?
04-27-2023 04:39
04-27-2023 04:39
Hi, @Suneel_S , if I understand correctly, you are saying that the green lights on the back of your Charge 4 are not flashing? Have you checked to make sure that the Heart rate has not accidentally been turned off? To check this swipe left on your Charge4 until you come to the settings menu. Tap to open and scroll down to find heart rate. Make sure it is set to ON. If it is set to ON but the greeen lights still aren’t working, try setting it to OFF, waiting a moment and then turning it back on again.
You could also try giving your Charge 4 a restart. Instructions are here
04-28-2023 02:35
04-28-2023 02:35
If the Heartrate is set to On but the green lights are not flashing, tap to turn OFF, wait a moment and then tap again to turn to ON. Hopefully this will reset it. It is also worth giving your Fitbit a restart as this can fix many issues.
Regards,
Will
