05-24-2020
08:33
16:17
05-24-2020
08:33
16:17
Hello,
Other Fitbit will vibrate when you set intervals to mark going from one interval to the next. The Charge 4 does not vibrate/buzz but only shows the interval is up on the screen. This makes the feature pretty much useless because now the user still has to look at their wrist the whole time to check the time.
Could this please be fixed? One of the reasons I bought mine is for the interval functionality.
Thanks.
06-29-2020 14:05
06-29-2020 14:05
Apologies for delay.
yes to both
09:11
03:43
07-03-2020
09:11
03:43
Hello guys, I hope you are doing fine.
I am glad to hear that for one of you this issue has been resolved. Keep in mind that I have escalated this issue to our team for further investigation. Once I receive any type of information about it, I will be glad to let you know.
Let me know if there is anything else I can help you with.
Best Answer07-06-2020 05:56
07-06-2020 05:56
That’s what happened with me as well, and it’s working now, with and without heart rate alerts. Thanks!
Best Answer08-03-2020 05:40
08-03-2020 05:40
I am having this same issue. Can you please let us know if there have been any updates? Can it be due to a broken tracker? I am sick of the interval function not working on my Charge 4.
08-04-2020 14:31
08-04-2020 14:31
Check your Do Not Disturb setting, if you haven't already. For some reason if that is turned on, the HIT won't vibrate. That was the problem for me.
08-04-2020 14:48
08-04-2020 14:48
Thank you
I’ll check it out.
Best Answer08-14-2020 09:30
08-14-2020 09:30
That was it! Thanks so much, such an easy fix to what I thought was a very severe problem! They were telling me to return it and everything but it was such a simple fix.
09-19-2020 13:18
09-19-2020 13:18
I am very disappointed with the Fitbit Charger 4! I have had my fitbit 2 for years and I loved it. I have had my fitbit 4 since May of 2020. It will not vibrate or make any sound. I have tried many strategies and had high hopes but to no avail . I am planning to sent my fitbit back and get something that will work. The tracker is suppose to help relieve stress not cause it.
Sincerely,
Freemont
Best Answer10-01-2020 06:16
10-01-2020 06:16
Hi! Do you know if this has been figured out yet? I tried using my interval timer for the first time this morning on my Charge 4 and the vibration was non-existent. It was really disappointing.
06:13
10:21
JuanJoFitbit
01-27-2021
06:13
10:21
JuanJoFitbit
I am also having this issue. The other vibration alerts work just fine, but it’s stopped vibrating to signal intervals! This is the main functionality for me. It’s also stopped alerting me to take 250 steps each hour. That’s the second principal thing I use it for. I’ve had this less than a year! How do I fix it? I’ve restarted, I’ve checked the settings, the problem persists. This is really making me regret getting a Fitbit instead of an Apple Watch. Please advise!
Has this been resolved? I have the same problem and this is the primary thing I use the Fitbit for, so I’m regretting my purchase. Can this be fixed?
Moderator edit: merged reply
Best Answer03-07-2021 23:25
03-07-2021 23:25
Hi all, I had the same problem and fixed it through setting the following:
do not disturb modus on
training signals on (directly below)
That helped for me, hope for you too!
03-08-2021
10:34
03:43
03-08-2021
10:34
03:43
Hey @isabellala, welcome to the Forums.
I appreciate the information provided about fixing this interval training issue. I know our fiends will find this really helpful.
Keep the stepping up!
Best Answer04-24-2021 05:34
04-24-2021 05:34
I faced this issue and found this thread. I got it working, here is what I did
1. Reset my charge 4
2. Went to the settings section on my device and turned on and and then turned off "do not disturb". it was already off but nevertheless did that once.
3. Interval buzz started working.
Hope this helps others.
-M
06-03-2021 11:08
06-03-2021 11:08
Check your DND setting. (Press and hold the button and tap DND if it is illuminated). I'd inadvertently enabled mine. As soon as it was disabled the interval workout buzzed when it was time to transition.
Best Answer07-12-2021 02:25
07-12-2021 02:25
I would like to know why this feature was removed, was it a cost decision? And what differentiates Fitbit from other health trackers now and which health tracker other than Fitbit would you recommend seeing that Fitbit takes away features without consulting the community at all.
08-26-2021 07:42
08-26-2021 07:42
Not sure if anyone's still looking for an answer on this, but I found the problem on mine. The update apparently turned on Fitbit's new Sleep Mode, which was unable to determine when I got up and started running. Once I figured that out and scheduled my Sleep mode instead of having it on, mine was all better.
10-09-2021 14:21
10-09-2021 14:21
Yes, that solved it for me too 🙂
Best Answer09-09-2022 11:01
09-09-2022 11:01
I have restarted and still no vibrating intervals.
09-09-2022 11:01
This doesn’t fix it. The intervals are set correctly and haven’t changed.
Best Answer09-09-2022 11:23
09-09-2022 11:23
Have you checked that DND is not turned on?
