12-30-2021
10:46
16:01
12-30-2021
10:46
16:01
Hello
My charge 4 isn't showing the sleep score anymore?
Kind Regards
Jon
01-01-2022 20:10
01-01-2022 20:10
I’m having the same problem.
01-02-2022 07:19
01-02-2022 07:19
Hi @Jonny88 and @SoCalGal66 are you seeing simple or advanced sleep? if simple sleep, please read the notice below the the simple graph.
What does it say?
01-02-2022 08:07
01-02-2022 08:07
It's OK again now thanks.
Kind Regards
Jon
01-02-2022 20:40
01-02-2022 20:40
For some reason, my Charge 4 is not showing the latest sleep data in the app. It's still showing week 20 - 25 December even though the dashboard online is showing the correct data. Syncing does not help.
01-03-2022 00:36
01-03-2022 00:36
Mine isn't showing Sp02 now. There's always something. It's showing a different amount of time slept to when you show the weekly data.
01-03-2022 09:10
01-03-2022 09:10
I called about this problem and they told me to put it back on the charger and hold the button down until the 🙂 came on. And then check that night to see if it worked. It worked the first night but then did the same thing after that.
