03-18-2022
22:15
14:42
03-18-2022
22:15
14:42
I have been using the Charge 4 for more than a year now. I always suspected that it did not measure my run distances accurately. I finally took my phone with me for a run. To my utter shock and disbelief, the Charge 4's distance was off by a whopping 3kms even with full GPS connectivity !!! I ran 8k but the charge 4 showed 11.3k. Now I'm concerned that all my previous runs was inaccurate and it takes away a lot of my personal accomplishments in terms of fitness goals.
It destroys the purpose of using an advanced fitness tracker in the first place.
Pls help
03-19-2022 16:49
03-19-2022 16:49
Kenne das Problem. Habe heute mein Zimmer Tapeziert. Sonst nichts. Habe laut Fitbit knapp 10 km geschafft. Mein Wohnzimner ist ca 8 Meter.breit ch bin also ca 1000 mal durch das Zimmer gelaufen? Bis auf die Etagenanzeige die sowieso komische Daten angibt, könnte der Rest aber stimmen.
01-31-2023 07:17
01-31-2023 07:17
Received a replacement for my broken Charge 4 from Fitbit. Thank you ! BUT... the distances are way off. I used two other devices to measure my walk. One was 2.33, the other (phone) was 2.53 and my Charge 4 was 1.56! I looked on the Community Help site and did as suggested with my settings, it made no difference. Has anyone found a solution?
