10-04-2020
03:51
16:17
10-04-2020
03:51
16:17
Health Metrics has appeared as a tile on my dashboard. It is supposed to report upon Breathing Rate ("BR"), Heart Rate Variability ("HRV") and Resting Heart Rate ("RHR"). This facility should be available to me as I have a compatible device (Charge 4), subscribe to FitBit Premium and I wear the Charge 4 to bed to track my sleep. Detailed sleep reports are available and RHR but in respect of both BR and HRV metrics it reports "No Data".
I cannot find any reference in the Charge 4 manual. Do I need to do something to switch on this functionality?
10-05-2020
06:48
07:55
10-05-2020
06:48
07:55
It's great to see you here, @Henry1953.
If you are not receiving your health metrics information, I recommend checking the following:
Let me know the outcome.
Best Answer12-02-2020 10:20
12-02-2020 10:20
My issue is similar but only BR breathing rate doesn't display while the other stats do display. HRV, RHR and Sleep display correctly.
Any suggestions will be appreciated.
06-28-2021
04:24
20:27
EdsonFitbit
06-28-2021
04:24
20:27
EdsonFitbit
Less than five months old and the last few days it's been dropping feature after feature. No spo2, then no breathing rate, then no hrv, then no sleep stats. For the price I expect more than 5 months before it starts to fail
06-28-2021 08:31
06-28-2021 08:31
Hi Alejandra,
The problem remains, but is sporadic. I wear my Charge 4 virtually all of the time, day and night, only excepting when it is on charge. Also, each time I charge it, I reset it (I have found that sleep scoring goes awry if it is not reset frequently). For example, my resu;ts for last night included:
Sleep Score: Full analysis (inc Time Asleep, Deep & REM, and Restoration)
Health Metrics
Breathing Rate (BR): No Data
Heart Rate Variabilty (HRV): No Data
Skin Temperature: Reported
Oxygen Saturation: Reported
Resting Heart Rate: Reported
Why would it monitor everything else but not BR or HRV?
06-28-2021 08:50
06-28-2021 08:50
I’m having the same issue. I wear my watch 24/7 and got 7 hrs of sleep last night. My stats have recorded consistently for almost a year until yesterday. Yesterday, HRV and Breaths per minute stopped recording. Today, my specific sleep stats were gone.
06-28-2021 11:21
06-28-2021 11:21
Same issue started a few days ago. Hadn’t had an issue prior.
06-28-2021 12:30
06-28-2021 12:30
Similar problem here with a Charge 4 (which replaced a non-functioning Charge 3 at the end of May). HRV and BR last reported on Friday, otherwise I have a good data for all of the other Health Metrics. Then last night, I only received basic sleep data. The latest version of the fitbit app was installed yesterday so I was hoping to see the Health Metrics issue resolved, but it wasn't and now I'm losing sleep data as well.
Please advise what I can do to fix the situation.
Thank you.
06-28-2021 13:57
06-28-2021 13:57
06-28-2021 14:26 - edited 06-28-2021 14:32
I have this exact situation: No HRV or BR data since Friday and I only have basic sleep data for last night. Makes me wonder if it's not something on Fitbit's data processing side (i.e. their web service) rather than with our devices. I have not updated the Fitbit app recently.
EDIT: My Stress Management score also isn't updating. I don't think it's the device but something in the app or service.
SECOND EDIT: According to the pink banner at the top of the community site now it looks like my assumption was correct.
06-28-2021
15:39
06:04
JuanJoFitbit
06-28-2021
15:39
06:04
JuanJoFitbit
I updated mine but it didn’t fix the problem 😟
I’ll try that, thanks!
I think you have a software issue. Several people have reported the same two features quit on the same day.
Moderator edit: merged reply
06-28-2021 16:11
06-28-2021 16:11
Same issue with me. Worked since inception of health metrics, until Saturday night.
06-28-2021
20:26
07:55
06-28-2021
20:26
07:55
Welcome to the Fitbit Community, @Bdapaul.
Thank you for the information provided.
Our team is aware of the issue with the Health Metrics (HRV and BR) and is working to identify a resolution as quickly as possible.
We're sorry for any trouble this situation could have caused. We appreciate your patience and look forward to getting you back on track.
If you are not getting SpO2 readings, please visit this article, open the menu "Why didn’t I receive SpO2 data?" and follow the instructions.
In addition, please check if there is any pending SpO2 app update:
Whether you don't see your sleep stats, please follow the steps in this article in the menu "Why don't I see sleep stages today?".
If you have any question, please let us know.
Best Answer06-29-2021 00:00
06-29-2021 00:00
Ok so this has supposed to have been fixed ,while most things are working it’s not fixed totally as of 07:54 GMT I have my units set to degrees C they are still showing in degrees F my phone a galaxy S20 ultra is compatible my software is android 11 everything is up to date ,the problem still exists I have tried every solution that I was asked to try nothing has worked so I think it’s Time to send back the Fitbit 4 as it’s not fit for the purpose it’s intended to do
Best Answer06-29-2021 00:28
06-29-2021 00:28
Slight improvement for me. Only RHR missing last night!
06-29-2021 03:44
06-29-2021 03:44
Best Answer06-29-2021 05:36
06-29-2021 05:36
I got both readings. I did disconnect from Bluetooth and reconnect after a few seconds yesterday. I have no idea if that’s why !
06:12
10:47
DavideFitbit
06-29-2021
06:12
10:47
DavideFitbit
All readings were back to normal today for me too!
Like you, I’ve sometimes turned off Bluetooth. Usually it’s when the Charge 4 wont sync that I turn off Bluetooth, until Fitbit asks me to turn it back on. Then it usually updates. Tried that for the health metrics info on Sunday but data for HRV and BR didn’t return until today.
Both HRV and BR returned this morning.
Best Answer06-29-2021 07:06
06-29-2021 07:06
HRV and BR have returned for me too as of this morning. Sleep tracking and stress monitoring have also returned.
Now could somebody please fix the issue with iron? I enter, e.g., 4% as the value for a food item on the website and it becomes 72% without any intervention from me when I check it through the app. It changes itself. I go back on the website and change it to 4% and by the time I check it again through the app it’s changed itself to some totally ridiculous value again.
06-29-2021 08:26
06-29-2021 08:26
All of my Health Metrics are now back this morning (RHRV, RHR, BR, Temp, SpO2), after I updated my Android device last night to Fitbit version 3.43.1. 😀
Using a Samsung Galaxy S10 (running Android OS 11) with my Fitbit Charge 4 (firmware version 48.20001.100.43).
