09-22-2022
14:28
13:05
09-22-2022
14:28
13:05
My gps setting is phone gps. My Fitbit is connected to my phone, and my phone gps signal is good. But when I start a workout, Fitbit trys to find gps, then says "Not Connected." What is it not connected to?
09-22-2022 19:06
09-22-2022 19:06
@Skepticrat , Nice to see you around.
The message you get, could mean, either the Charge 4 is not connected to your phone or that the Fitbit App could not connect to a GPS .
Either case I would recommend you to have a look at this: How do I turn on GPS for an exercise on my Fitbit device?
How do I get my Fitbit device to connect to GPS?
Hope it helps
Best Answer09-22-2022 19:27
09-22-2022 19:27
As I said, my phone is connected to my Fitbit, and my phone has a GPS signal. the Fitbit app has 4 green bars for GPS and shows my location correctly.
Best Answer09-25-2022 18:26
09-25-2022 18:26
@Skepticrat , Thank you for your reply and confirmation.
It seems that the Fitbit app on your phone is not allowed to run on the background or when the display of the phone is off. So it gets disconnected.
Please on the phone's settings go to apps>Fitbit App >(usually you'll find the correct settings under Battery settings)
Hope this helps
Best Answer09-26-2022 16:20
09-26-2022 16:20
It's not that. Battery setting is on "Unrestricted" and always has been. It worked fine until 2-3 weeks ago. The only thing that changed is that the GPS stopped working.
It worked last time I went on a run--hopefully it just fixed itself.
09-26-2022 18:34
09-26-2022 18:34
@Skepticrat , Thank you for taking the time to check the settings.
I'm glad to hear that the situation got solved on your last run.
Keep me posted if anything recurs again.
