02-28-2022
16:34
15:30
02-28-2022
16:34
15:30
My fitbit band broke, the piece that you click it into broke, I received my replacement. Now It is trying to pair with my old one. I keep
hitting cancel, and tell it to forget this fitbit, but it keeps trying to pair with it??What can I do to
stop it. My new fitbit is working fine, have no
idea why it is trying link to my old fitbit?
Thanx, Barbara
03-01-2022 05:35 - edited 10-30-2023 03:33
Hi there, @55Bar59. Thanks for stopping by in the Community Forums and sharing the details about the issue with your Charge 4.
It seems that your new Charge 4 cannot connect properly to your phone since you haven't yet forgotten the connection between your old Charge 4 and the phone's Bluetooth which would explain the connectivity issues you're running into. With that said, try the steps below:
Hope that helps.
Best Answer03-02-2022 17:29
03-02-2022 17:29
Not sure how, especially since It was working, and it does work on my Samsung flip phone?
