06-06-2020 19:37 - last edited on 12-14-2022 16:20 by MatthewFitbit
The light on my charge 4 is so dim I can hardly read the face. The battery is fully charged.
What can I do to correct this issue.
10-09-2020 17:12
10-09-2020 17:12
Hi @Nic2873. Welcome to the Community Forums.
Thanks for sharing that your Charge 4 screen is having the same issues and for trying the suggestions from this thread. Because the screen is too dim and doesn't show your data when going outside persists, I've contacted our Support team and shared your details so they can create a case on your behalf. Please note that due to recent events affecting our operations there might be a delay in their reply, but they'll get in touch with you soon.
Let me know how it goes.
11-22-2020 05:17
11-22-2020 05:17
Mine is so dim I can't see it anymore in a completely dark room. The pixels across the top have been dying completely for a while. Planned obsolescence?
11-23-2020 10:51
11-23-2020 10:51
Hi @ebertoli. Welcome to the Community Forums.
Thanks for letting me know about your Charge 4. I understand how you're feeling about the screen not working correctly and I'm sorry for this inconvenience. Because your post didn't mention, may I know if you've tried restarting your tracker and changing the clock face? If you haven't, please give it a try and let me know the outcome so I can continue helping you with this matter.
I look forward to your response.
11-30-2020 09:54
11-30-2020 09:54
Hello,
My wifes charge 4 is facing the same problem. Tryed reset and checked Setting. Stil to dim to read outdoor and indoors. Only possible to read in dark conditions.
11-30-2020 10:50 - edited 11-30-2020 10:52
Hi, @tino61 , welcome, have you tried the "Best Answer"? There are three settings that affect the brightness of your Charge 4 Touch the side button for a couple of seconds and you are presented with "do not disturb" and "sleep", you can also swipe up for "screen wake". DND disables notifications, "Sleep" disables notifications, dims the screen and disables the wrist flick action to illuminate the screen and defaults the dimmed illumination to the side button. This last feature is designed to avoid disturbing restless sleepers who might inadvertently illuminate the screen at night. From the clock screen swipe left to "settings" where you are presented with "Brightness", you can toggle between Auto, normal & dim, choose auto or normal. Finally swipe up to "sleep mode" where you can schedule sleep settings, you need to ensure you are not in a sleep period or that it is off.
I hope this helps.
Cheers
Gr4ndp4 | UK
11-30-2020 12:04
11-30-2020 12:04
12-03-2020 16:55
12-03-2020 16:55
Hi @tino61 and @bluemusicnut, welcome on board. @Gr4ndp4, it's good to see you around and thanks for your great suggestions.
@tino61, thanks for letting me know about your wife's Charge 4 and for every step tried prior to posting. I understand how difficult for her it's to see the screen and to exhaust our troubleshooting steps, please follow the suggestions posted by @Gr4ndp4. Give them a try and keep me posted with the outcome.
@bluemusicnut, thanks for trying the suggestions posted in this thread. I'm sorry they didn't work on your Charge 4 and I've requested a case on your behalf so our Support team can provide you with further assistance. Please note that due to recent events affecting our operations there might be a delay in their reply, but they'll get in touch with you soon.
See you around.
04-21-2021 19:37
04-21-2021 19:37
I also have trouble reading my charge 4 screen with any sunlight, even on cloudy days it is hard to see. I have the brightness setting on max, or on normal which is the highest it can go. With a cupped hand and lots of focus I can read it but only if I stop running, the lettering is too dark of a gray and the screen too dim. Is there any way to fix this?
04-22-2021 12:51
04-22-2021 12:51
Welcome to the Community, @Gotch.
Thanks for checking the brightness settings prior to posting. Before anything else, may I know if the Sleep Mode is off? When this setting is turned on, the screen's brightness is set to dim. To check this, press and hold the button, swipe left to access the quick settings screen and tap on the moon icon to turn it off. If the icon appears dim with a line through it, that means it's off.
If the screen is still dim after checking this setting, please try performing a restart with the charging cable and keep me posted with the outcome.
See you around.
04-22-2021 13:07
04-22-2021 13:07
04-22-2021 13:07
04-22-2021 13:07
Thank you for your advice but it didn’t work. Is there an app, extension, or update of some kind I can install to make it brighter?
04-23-2021 11:03 - edited 04-23-2021 11:20
Hi @IanSevenoaks and @Gotch. I'm glad to see you here.
@IanSevenoaks I'm sorry for the inconvenience that you've had with the Charge 4. Our team constantly works to improve the Fitbit experience with our products and services, and the feedback we received from the Community is always appreciated as it help us to evaluate our procedures and make sure we're delivering what our users want and need. Your feedback won't be the exception and please know that you're always welcome back to the Fitbit family.
@Gotch Thanks for trying the suggestions posted above. Currently we don't have another way to increase your Charge 4 screen brightness and because our troubleshooting steps have been exhausted, I'd recommend to get in touch with our Support team so they can provide you with further assistance. Please click here to get connected with them via chat or phone.
Have a good day.
06-21-2021 11:31
06-21-2021 11:31
There is no option under Settings for brightness...just time zone and location...my screen is so dim indoors I can't read it.
06-21-2021 11:49 - edited 06-21-2021 11:50
Hi, @kymber13, allowing you have investigated the "sleep" & "DND" settings suggested in my earlier post, I suggest contacting "Customer Support" here. I recommend you use the Chat facility or the phone for a prompt response.
Cheers
Gr4ndp4 | UK
08-08-2021 08:41
08-08-2021 08:41
Not working for me
08-09-2021 17:41
08-09-2021 17:41
Hi @kymber13 and @Tinagillis. Welcome to the forums. @Gr4ndp4 Thanks for your great help!
@kymber13 Please note the screen settings can be adjusted on your Charge 4 itself. To do this, just swipe left on your tracker's screen, tap Brightness and adjust it to either Auto or Normal. If this doesn't help, please follow the suggestions shared by @Gr4ndp4 to get connected with our Support team.
@Tinagillis I'm sorry your Charge 4 screen is still dim and thanks for your efforts while working on this situation. Because your post didn't mention, may I know if you've tried adjust the brightness, turning off the Sleep Mode and restarting your tracker? If that's correct, I'd recommend getting in touch with our Support team so they can evaluate your options and bring you back on track. Please click here to get connected with them via chat or phone, and make sure to share the steps that you've tried so far.
See you around.
08-09-2021 17:48
08-09-2021 17:48
08-12-2021 16:14
08-12-2021 16:14
@Tinagillis It's nice to see you around the forums.
You're very welcome! I'm glad you sorted this out and I hope you can keep crashing your steps. By the way, let me invite you to visit our Health & Wellness board where you can make new friends, share your story and find encouragement from other members to live a healthy lifestyle.
Have a good one.
08-28-2021 22:26
08-28-2021 22:26
Tried that. Nothing seems to work.
08-29-2021 07:24
08-29-2021 07:24
Totally dead now for a few months. The screen dimming was only a death knell. I have gotten over my addiction of buying high dollar disposable fitness watches. Unless they make Fitbits that have the option to change out the battery, I'm done with Fitbits for sure.
