01-18-2022
02:52
06:23
01-18-2022
02:52
06:23
My Charge 5 is on 18months old and it is not so dull I can hardly see it. The pixels at the top are also starting to disappear. Is it normal for this happen. For a watch I paid $250 for I would expect it to last longer than 18months.
01-18-2022 02:54
01-18-2022 02:54
Sorry it is a Charge 4
01-18-2022 03:42
01-18-2022 03:42
My screen won’t work either I’ve restarted it but then it goes off again & nothing
01-18-2022 08:18
01-18-2022 08:18
I have the same problem.
01-18-2022 09:38
01-18-2022 09:38
Same for me screen to dim to see.
Best Answer01-18-2022 09:41
01-18-2022 09:41
01-18-2022 11:29
01-18-2022 11:29
My Charger 4 display has been doing this since I bought it a year ago.
Best Answer01-18-2022 11:31
01-18-2022 11:31
Best Answer01-18-2022 11:57
01-18-2022 11:57
01-19-2022 03:57
01-19-2022 03:57
Best Answer01-19-2022 05:47
01-19-2022 05:47
Hi, there must be multiple reasons for the screen to become harder to see going by other posts. I first swapped to a different clock face, but now that is getting hard to see unless it's in a low light level - the screen also has a striped appearance suggesting that the display is actually failing. I have also tried cleaning the light level hole on the 'button' side but that did not work. It is poor for a product that is not that old.
Best Answer01-19-2022 08:17 - edited 01-19-2022 08:20
Hey hey hey, welcome to our community! I'm sorry to hear that your Charge 4 screen is hard to see. Thank you for mentioning the steps you have followed and for your advise.
If your Charge 4 screen is getting dim check the display settings for the brightness, that it is not in DND or sleep mode and restart your device. You can also try changing the clock face.
You can restart your tracker from your wrist. Open the Settings app and tap About > Reboot Device.
If your Charge series tracker is unresponsive: .
Your tracker should now work normally. If your tracker still doesn't work after a restart, contact Customer Support.
Best Answer02-25-2023 17:47
02-25-2023 17:47
My Charge 4 is doing the same. Pixels dim/dead so the time doesn’t read properly.
Best Answer02-26-2023 02:22
02-26-2023 02:22
Hi, Lots of the problems are to do with hardware failure, I got the offer of a replacement or discount on new product, best to reach out to customer support.
