10-11-2023 08:11
10-11-2023 11:12
10-11-2023 11:12
I have no solution I’m afraid, only to say that in recent months mine has gone exactly the same.
I’m buying a new Charge 6 shortly so hopefully it won’t matter soon
10-11-2023 12:48
10-11-2023 12:48
10-11-2023 12:53
10-11-2023 12:53
Dunno. Year and a half I suppose. I only noticed it a few weeks ago. I can’t remember when I bought it. Maybe 2 or 3 years ago?
10-11-2023 19:37
10-11-2023 19:37
Mine, as well. I’ve checked Settings to make sure it’s set to “normal” and don’t have an option for “bright”, but it’s still very, very, very dim.
10-11-2023 21:42
10-11-2023 21:42
10-14-2023 09:56
10-14-2023 09:56
Try to see if your Do NOt Disturb has been turned on accidentally.
It is holding the left side of the tracker, with your thumb, until DND shows up & a Sleep thing at the bottom of the screen !
Just Tap the Screen & see if that sorts it out.
Somehow I fixed it with my old one, & it was really bright & so clear, but now I'm having a problem with the same issue, with my new unit
that I have only just connected to the App after disconnecting the old one !
I hope you have some luck with it.
