11-02-2022
19:19
15:36
11-02-2022
19:19
15:36
The face of my charge 4 can only be accessed by pressing side button. Very inconvenient.
11-03-2022 03:29
11-03-2022 03:29
Hi there, @Debbiegfamily. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Charge 4.
As @JohnnyRow has mentioned, please go to your quick settings and check that screen wake hasn't accidentally been turned off. Press and hold the button, and swipe left to access the quick settings screen. Change whether the screen turns on when you turn your wrist. For more information, see How do I navigate my Fitbit device?
If this settings is set correctly, please try restarting your Charge 4 by following these steps: How do I restart my Fitbit device?
Hope that helps.
11-02-2022 19:32
11-02-2022 19:32
Check that you don't have 'Screen Wake' turned Off' or are in 'Sleep Mode' - both in Quick Settings.
11-03-2022 03:29
11-03-2022 03:29
Hope that helps.
11-03-2022 04:17
11-03-2022 04:17
Thanks for your reply. The problem is that the screen is completely blank so any swiping doesn’t show me what is on the screen - chicken and egg… or am i missing something please.
11-03-2022 04:18
11-03-2022 04:18
Thanks for your reply. The problem is that the screen is completely blank so any swiping doesn’t show me what is on the screen - so i can see any menues - chicken and egg… or am i missing something please.
11-03-2022 04:20
11-03-2022 04:20
I have already tried restarting the device. I feel the vibrations but at the end, the screen is still blank.
11-06-2022 08:46
11-06-2022 08:46
I don’t understand why this is rated as BEST ANSWER. The issues is not fixed. I was never asked if it was fixed. The swipe left doesnot work because the screen is completly blank. Swipe left even with button pressed does not make any of the menus visible. I have tried the restart but the screen is still blank. ABSOLUTELY NO display at all. Is it possible to reset screen brightness from the app on IOS
11-06-2022 09:13
11-06-2022 09:13
@tonmilx Looking at the times on the posts, it looks like the original poster and the post marked the best answer were both posted before your post, and you added your issues onto the end of another post, unless someone moved your post here. I expect the original poster marked the best answer. Sometimes it is best to start a new thread for cases such as this because the post marked 'best answer' apparently solved the original poster's problem, but did not solve your issue.
