12-09-2020
18:58
16:17
12-09-2020
18:58
16:17
Same exact thing happened to by charge 4. Did you find a solution?
12-10-2020 06:25
12-10-2020 06:25
@EvelynHiggins It's great to see you in the Community!
Let me help you with this issue. You don't mention any troubleshoots so I suggest you restart your tracker by doing the following:
I also moved your post to the correct board.
Let me know how it goes.
Best Answer07-20-2021 23:50
07-20-2021 23:50
Hi there. I have the same problem. I've tried the restart twice. Each time I get the smilely face, but then the fitbit continuous to have a black screen and to vibrate continuously when touching the side. Is there another fix?
07-22-2021 12:50
07-22-2021 12:50
Welcome to the Fitbit Community, @Vincentvbd.
Thank you for joining the thread and sharing that you're experiencing the same issue with your device. I appreciate your troubleshooting efforts. I recommend getting in touch with our Support team so they can evaluate your device's behavior and help you with this matter. Click here to get connected with them via chat or phone.
See you around.
10-08-2021 02:48
10-08-2021 02:48
Just wondering if anyone had this issue sorted for them? If so what was the prognosis
10-08-2021 06:36
10-08-2021 06:36
It’s good to see you in the community, @Chanley43.
Thank you for joining the thread and sharing your concern. If you're experiencing the same issue with your device, I recommend following our troubleshooting instructions including a restart in this help article: Why isn't my Fitbit device's battery charging?
Hope this helps.
Best Answer01-25-2022 09:05
01-25-2022 09:05
no. nor will you get one. I was one month out of warranty and was given a "generous" discount by support staff after I pointed out I had been attempting to reach them for a couple of months to no avail. Black screen, still not working, but can feel all the functions it should have running. Got a new one, my last one from them, it works but am still hoping to get the other one working but cant try the new clock face test since it needs to pair and I cant read the screen! I am switching brands after this as I found a couple of others that are better covered and may cost a bit more, but their customer service is reportedly outstanding. I have been with fitbit for many years and this isnt the first time I have gone thru this. I have had five different models thru the years, but no more for me. Im highly dissapointed.
04-15-2022 20:16
04-15-2022 20:16
This solution did not work.
04-29-2022 08:37
04-29-2022 08:37
I'm in the same place. Love using my Fitbit. Got first one 1.5yrs ago, used the first one for about 4-6 months, LOVED it. Simple and gives me the data I need.
After it stopped working, same issues, vibrates, the screen won't turn on.
Then i got my replacement...stopped using it in sauna, while swimming, really avoided all the things. Same issue few months later. Not sure if I got a refurbished one and just have bad luck.
Then, I called them and submitted a lot of requests to get this issue fixed. Sent them my Fitbit around holidays, did not hear for 4 months, then out of nowhere, they send me a replacement. 1 month into it ... Last night charged it. Put it on the wrist, doesn't turn on. Just vibration.
05-02-2022 14:03
05-02-2022 14:03
This did not help, I restarted it twice and screen is still very dim.
05-06-2022 12:34
05-06-2022 12:34
Exact thing just happend to mine. Just died on the wrist mid morning today with over 85% charge. Had to wait to get home to try the useless reset options via the charger. Anything I do just results in the smiley face apprearing for <30secs then the haptic button vibrates when I touch it. Screen remains black. Device still syncs I think but nothing on the screen. Had mine since Nov 2020. Any further feedback on this would be appreciated of anyone is out there!
05-22-2022 22:49
05-22-2022 22:49
I love my Charge 4, but it went blank and only vibrates when I press the power button on the side. The smiley face icon appears, but my device doesn't turn on.? Multiple charging attempts and Google searches to try and fix. Super disappointed. I've only had it for less than 2 years.... money wasted.... now I'll look at other smart watch options...
05-23-2022 06:03
05-23-2022 06:03
I have a USB port that I always use to charge mine and wife's Fitbit Charge 4. A couple of days ago I put my Fitbit on charge and forgot to take it off. When I had put it on charge it was around 15%.
Upon removing it this morning (2 days later) I saw that the screen had gone blank. I took the device off the charger and tried to long press the haptic button multiple times. I timed myself for long-pressing on one occasion for up to 40 seconds. Everytime the device would vibrate for a long time (like 5-7 seconds) and then produce a short vibration (like a beep), but still nothing.
I then plugged it back into the charger and tried turning it on. Still nothing.
As a last resort, I unplugged the charger from the USB port and plugged it into another USB port (on another device) and long pressed. This time the device woke-up. I saw the smiley face and the screen came on. What was interesting was that the battery was at 11%, which means the device hadn't charged at all!
But I'm happy state that my Fitbit is up and running again.
06-10-2022 06:43
06-10-2022 06:43
Hi JoeyBunn17. Did you ever get a fix for your Fitbit? I'm not finding anything to help, so I'm looking for another brand that is more reliable. I can't just throw a couple hundred dollars away every year for Fitbit. thanks!
06-10-2022 07:19
06-10-2022 07:19
I contacted customer service and will update the forum if the issue can be fixed.
06-11-2022 08:25
06-11-2022 08:25
So essentially your fitbit is toast, and if it has been over a year since you've had it you're screwed. They will offer a discount on your next purchase. I went with the Amazon version of an activity tracker this time. Monitors everything FB does but only costs $30. If it breaks in a year then it only costed $30.
06-16-2022 08:53
06-16-2022 08:53
Mine is doing the exact same thing everyone else is describing. No screen, but vibrates when pushing the button. A hard restart will produce a smiley face, but then will immediately go dark again and will only vibrate on button press. Any solution to this at all?
06-19-2022 04:43
06-19-2022 04:43
Same problem here.... it seems that this is a problem for many people.
Fitbit should resolve the issue as this is a product failure.
07-07-2022 13:10
07-07-2022 13:10
Thank you. This worked for me too. I was using an old cheap plug/usb adaptor and switched to the USB drive on my laptop and now it is charging.
Best Answer07-07-2022 13:15
07-07-2022 13:15
I followed RayFitSweden's advice and used the USB port on my laptop instead of the block I had plugged into the wall and suddenly it started charging and quit buzzing. Yes, it was an old cheap charging block that worked for other devices but not my Fitbit. I'm glad I don't have to buy another one or go through the hassle of sending it in. Thanks Ray!
