12-25-2021
08:12
16:04
12-25-2021
08:12
16:04
My charge 4 has stopped vibrating for reminders to move. Additionally it no longer receives text notifications or any other app notifications.
my iOS is up to date. I have rebooted and paired with my iPhone. I have checked to be sure do not disturb is off. I have my charge 4 set to vibrate strong.
I’m hard of hearing and this is a critical feature for me. please help
12-25-2021 18:15
12-25-2021 18:15
Hi there, @Coco_Rottie. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Charge 4 before reaching out. I understand where your concern is coming from.
If you haven't done so yet, I'd recommend taking a look at these two help articles Why didn't my Fitbit device alert me? and Troubleshooting quick tips for iPhones
Hope that helps.
Best Answer12-25-2021 18:15
12-25-2021 18:15
Hope that helps.
Best Answer02-28-2022 16:38
02-28-2022 16:38
Im beginning ti fekl lije this is a tech glitch with the Charge 4 trackers. I am having the same issue and none of the steps advised has worked.
Did your issue get resolved?
Best Answer03-01-2022 07:38 - edited 04-18-2024 09:12
@Alvetam Thanks for trying to troubleshoot the issue with your Charge 4. We‘re taking your comments and sentiments in regards to our products into consideration.
Please check if your Charge 4 isn't either on sleep mode or DND. When the do not disturb setting is on, notifications, goal celebrations, heart zone alerts, and reminders to move don't cause the tracker to vibrate or the screen to turn on.
When the sleep mode setting is on:
Sleep mode doesn't automatically turn off unless you set a sleep mode schedule. For more information, see How do I navigate my Fitbit device?
Best Answer01-10-2023 20:19
01-10-2023 20:19
My charge 4 has started doing the same thing today. I check my do not disturb and sleep. They are both fine.
