04-14-2021
15:24
16:09
04-14-2021
15:24
16:09
I just got my Fitbit charge 4 two weeks ago- everything was going smoothly- for the last few days it has stopped vibrating my cardio and fat burning and zone points during boot camp. It has stopped vibrating for incoming messages AND most disappointing, it has stopped giving me my ten minutes step reminder. I have reset, resynced, turned all notifications off then on again to try to get it going to no avail. Now just today I noticed it was not counting my steps two different times today until I shook my wrist and tapped the watch. Is this defective or because of the latest update? If so I need to return ASAP. Any insight would be great! Thank you!
Has anyone else had this problem?
09-12-2021 17:59
09-12-2021 17:59
I'm ready to return my Fitbit. It's nothing but a glorified watch tight now. Anybody have any insight why the notification stopped working?
09-12-2021 18:36
09-12-2021 18:36
09-12-2021 19:29
09-12-2021 19:29
09-13-2021 01:15
09-13-2021 01:15
The same with me. So disipointed.
09-13-2021
04:31
07:25
JuanJoFitbit
09-13-2021
04:31
07:25
JuanJoFitbit
I've had my Charge 4 since January and it stopped vibrating and sending me notifications last week. Also the numbers are dimmer and it doesn't light up when I move my wrist.
Thanks, Silvia! The sleep mode was definitely my problem. My Charge 4 is vibrating again.
Moderator edit: merged reply
09-14-2021 14:29
09-14-2021 14:29
Hi everyone,
Thank you for the details mentioned and the troubleshooting performed. I see where your disappointment is coming from.
If you stop receiving notifications on your Charge 4 from one day to another, I highly recommend to check the following as it has helped others:
To test the Charge 4's vibration motor, connect the tracker to the charging cable and check if it vibrates.
Hope this helps.
09-14-2021 16:08
09-14-2021 16:08
Me too shortly after getting it as well. I am just so disappointed with this charge 4 after my charge 2 died, that I'm researching fitbit competitors to see how they compare to the next charge device coming out soon.
09-14-2021 16:49
09-14-2021 16:49
09-14-2021 17:51
09-14-2021 17:51
This seems counterintuitive and obtuse as a UI.
09-15-2021 15:28 - edited 09-16-2021 12:44
@Brokefang_no1 Hi there. I see where your disappointment is coming from.
I'd like you to ensure that you've tried the procedure mentioned here. If you have but still experiencing difficulties, as mentioned by @Kaysy you could always get in touch with our Support team, they'll continue assisting you.
@SquareState Hi there. Your feedback is appreciated, we're always striving to improve our services offered.
Hope this helps.
09-15-2021 16:54
09-15-2021 16:54
I followed this procedure and still do not get the alerts 10 minutes before the hour if I haven't already achieved 250 steps.
I set an alarm just to be sure vibrations (which is set to normal) were working and it did vibrate this morning, so it's not that.
09-16-2021 12:46
09-16-2021 12:46
@SquareState Thank you for getting back.
Let's try restarting your Charge 4 and set up the reminders to move from the online Dashboard.
Hope this helps.
09-16-2021 19:45
09-16-2021 19:45
This is happening to me too as of today
09-17-2021 17:50
09-17-2021 17:50
@Cgris Welcome to the Fitbit Community.
Please confirm the troubleshooting mentioned here was performed.
Hope this helps.
09-17-2021 21:14
09-17-2021 21:14
You can't really call rebooting the device and hoping the problem goes away "troubleshooting." Nevertheless I did restart the Charge 4 and I went to the profile where I confirmed that reminders to move was enabled; I wont know whether it reminds me until 8:50 tomorrow (assuming I haven't by then walked the requisite 250 steps).
09-18-2021 08:57
09-18-2021 08:57
The buzz did not happen at 8:50 or 9:50. The reminders to move is set up exactly as it has been for the last 4 or 5 years since the feature was introduced - 10 hours a day, 8:00 to 18:00 7 days a week and reminders are ON.
09-21-2021 08:56
09-21-2021 08:56
Thanks for the tip to deactivate the ‘do not disturb’ and ‘sleep mode’ on my charge4.
it vibrates again when getting to 10 minutes before the hour and not having done my 250 steps!
09-22-2021 15:35
09-22-2021 15:35
Take into consideration that we exhaust all the recommended steps before proceeding with anything else. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
@Vero63 Welcome to the Fitbit Community. Thanks for the details mentioned. Glad to hear that once you checked your settings, everything went back to normal.
See you around.
09-23-2021 05:11
09-23-2021 05:11
Miy Fitbit Charge 4 is also still not working correctly; no vibrations no Whatsapp nor Gmail messages etc.
All solutions mentioned were not succesfull.
Please give a helpfull solution. Maybe a new update?
09-23-2021 05:28
09-23-2021 05:28
Mine's vibrating now, but when I raise my hand to see what it says, it doesn't light up. ;(
