07-31-2020
08:58
16:17
07-31-2020
08:58
16:17
Went for a 5 min swim in pool and then my Fitbit just stopped working. Tried charging / reset etc but simply seems to have died. Any fix...(?)
07-31-2020 10:01
07-31-2020 10:01
odd. did you towel dry it after coming out of the water?
Best Answer08-01-2020 00:53
08-01-2020 00:53
08-01-2020 12:32
08-01-2020 12:32
f you haven't already I would call support and get a case opened
08-02-2020 08:45
08-02-2020 08:45
I’ve got the same problem..
08-08-2020 23:17
08-08-2020 23:17
I am having the same problem after a very short swim. I have only had it for 3 days. I dried it off when I was done, but the screen stayed black.
It is incredibly frustrating to have something so new and expensive not working, especially because I specifically got this one to be able to track swims.
08-08-2020 23:23
08-08-2020 23:23
Have you tried holding the button for 10 seconds to restart?
Gr4ndp4 | UK
08-08-2020 23:29
08-08-2020 23:29
Unfortunately I did. It just vibrates for ten seconds and nothing happens.
Best Answer08-08-2020 23:35
08-08-2020 23:35
You should probably call support.
Gr4ndp4 | UK
Best Answer08-08-2020 23:39
08-08-2020 23:39
Have you watched
https://www.youtube.com/watch?v=RergqNUcZa0
Gr4ndp4 | UK
Best Answer08-21-2020 09:44
08-21-2020 09:44
Bought on 7/21/20. Did water aerobics class in the pool on 8/13/20 and it died once the class was done. I wiped off the connectors with rubbing alcohol, tried reset, but absolutely NO vibrations at all. Even tried to put it in rice for 24 hours, still nothing. Chatted with support but they had to create a case and forward on to another department. So bummed because I specifically bought this model so I could swim with it since my Charge 2 died recently while paddle boarding. I hope they will replace it. I purposely did not want the larger face and thought the 4 would be perfect.
08-21-2020 10:07
08-21-2020 10:07
If you cant restart or reboot I think you should contact "Support". I swim every day using the Autostart and have no problems.
Cheers
Gr4ndp4 | UK
08-21-2020 10:28
08-21-2020 10:28
They are replacing mine, but you should know that it will be a long wait to make it happen. It takes about a week for the other department to respond, then about a week for it to get to their warehouse. I was told it could take up to a week for them to process the return and I am sure it will take about a week for the new one to arrive after that. So they will replace it, which is great, but it will be a while.
08-21-2020 17:08
08-21-2020 17:08
Thank you 😊
Best Answer02-11-2022 06:22
02-11-2022 06:22
I had the same issue twice with charge 3, they are not water proof up to 50m. They have a swim setting but anytime I’ve used it, my Fitbit stopped working- wouldn’t buy again. Probably better with Apple Watch
Best Answer04-22-2022 09:08
04-22-2022 09:08
Same happen to me just now with charge 5
After swim got water damaged. I can see watter droplets inside.
I thought this suppose to be water resistant 😤
04-22-2022 10:13 - edited 04-22-2022 10:15
Hi, @BlueWatter, welcome to the community, I recommend you talk to "Customer Support" here, and use the chat facility or phone for a prompt response.
Cheers
Gr4ndp4 | UK
