Charge 4 stopped working after swimming
ANSWERED
I wore my charge 4 swimming for the first time yesterday and it stopped working.
1 BEST ANSWER
Accepted Solutions
Hi there, @MotionDetector. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Charge 4. I understand where your concern is coming from.
Please note Charge 4 is water-ressistant to 50 meters. However, water resistance may diminish over time and can be negatively impacted by any of the following:
  • Dropping the device.
  • Exposing the device to soaps, shampoos, conditioners, perfume, insect repellent, lotions, or sunscreen.
  • Exposing the device to high-velocity water (for example, during water sports).
For more information, see Can I swim or shower with my Fitbit device?
Nevertheless, I'd recommend restarting your watch by following these steps How do I restart my Fitbit device?
If the restart doesn't work, let's move forward with the steps below:
  • Clean the charging contacts on the back of your device and the pins on your charging cable using the instructions in How do I clean my Fitbit device?
  • If the error "insufficient power source" appears on your device's screen, remove other devices plugged in to your power source, or plug your device in to another source.
  • Try a different USB port or a UL-certified wall charger.
  • Check the alignment and try reconnecting your device to the charging cable. For more information, see How do I charge my Fitbit device?
  • Restart your Fitbit once again.
Hope that helps!
1 REPLY 1
Hope that helps!
