Charge 4 went off 7 miles into run
charge 4 went off 7 miles into my run and all data lost ,
was tracking fine up to that point
was not flat as 28% when battery when I connected it to charger.
Once it was back on i sync'd it and all the run data , timings and measurements etc were lost
battery is draining much faster, needing to charge every 3 days.
This is not first time it has shut off with ample battery life remaining.
Latest updates installed so this is frustrating given I have a HM in 3 weeks
3 REPLIES 3
@Sheffmum , Nice to see you here. Thank you for your message and feedback.
Does it occurs when you are using GPS or even without it?
Have you restarted your Charge 4?
Did this happened afterwards also?
See you around.
Sent from my iPad
@Sheffmum , Thank you for your reply but it seems empty. Could you please try to send it again?
See you around.
