03-29-2021
11:54
16:09
03-29-2021
11:54
16:09
Fit bit 4 is not pairing or connecting to blue tooth this has only happened since clocks went forward
03-30-2021
18:02
03:31
03-30-2021
18:02
03:31
Hi @Stringy67 Welcome to the Community Forums.
Thanks for bringing this to our attention. To look into this may I know if your phone is the only Bluetooth device next to your Charge 4 when trying to sync? If not, I'd suggest you to either take that other device to another room or turn off its Bluetooth settings to prevent any interference with the connection.
Additionally, please give a try to these other steps in the following order:
03-30-2021 23:46
03-30-2021 23:46
04-04-2021
15:36
03:27
04-04-2021
15:36
03:27
Hi @Stringy67 I'm glad to see you again.
Thanks for getting back with more details about this situation. I understand how you're feeling about having this issue with your Charge 4. Because your post didn't mention, did you try the steps suggested in my post? If not, please given them a try on your iPhone making sure to turn off the Bluetooth in your iPad. Once your tracker has synced, turn off the Bluetooth in your iPhone to sync with the Fitbit app. Please note that the pairing request must be accepted in your iPhone so your notifications can go through your tracker correctly.
04-15-2022 23:11
04-15-2022 23:11
Tried all this & it still keeps doing it. Maybe an app update will fix the issue when fitbit do the next one,
04-19-2022
12:58
04:12
04-19-2022
12:58
04:12
Welcome to the forums, @Latrru.
Thanks for your efforts while troubleshooting your Charge 4. I'm sorry for this inconvenience and to look into this, may I know the model and OS version of your phone? Also, do you have other Bluetooth devices nearby? Please note having multiple Bluetooth connections at the same time might interfere with the syncing process.
In the meantime, let's try reconnecting your tracker to the Fitbit app:
04-21-2022 09:30
04-21-2022 09:30
I’ve completed all the above steps but still the message appears and now I’m not getting any notifications on my wrist at all
04-21-2022 17:59
04-21-2022 17:59
This has been happening with me for both my Charge 4 and my Inspire 2; it says I'm connected but when I try and go for a bike ride, it doesn't track the distance. That happened to anybody else?
04-25-2022
16:20
04:12
04-25-2022
16:20
04:12
Hi there, @Bikerman90. @RebelReynolds Welcome on board.
@RebelReynolds Thanks for trying the steps suggested above. I'm sorry you're having this experience and to look into this, may I know what is the error message that you're getting? Also, what is the model of your phone? I'm asking this as depending on your phone, there are some requirements that need to be met in order to receive notifications. If you haven't done so, please make sure to exhaust the troubleshooting described in here.
@Bikerman90 Thanks for letting me know about your Charge 4 and Inspire 2. Because you mentioned they won't track the distance, do you refer the GPS doesn't stay connected? If that's correct, let me recommend this help article which describes what factors impact the GPS connection, and some tips to improve its accuracy.
04-26-2022 01:56
04-26-2022 01:56
Thank you I have followed all the instructions on the link you sent me and I’m still not getting any notifications on my wrist. I’ve got the iPhone 11 and when I open my Fitbit app I get and error message. See photo attached
04-26-2022 02:04
04-26-2022 02:04
It was the update. The new update came out & all was fixed.
04-26-2022 02:09
04-26-2022 02:09
Sadly not still not working
05-01-2022
16:10
06:01
05-01-2022
16:10
06:01
Hi there, @RebelReynolds and @Latrru.
@RebelReynolds Thanks for troubleshooting your Charge 4, and the screenshot provided. Let me share this issue with the iOS Fitbit app showing that message has been reported to our team and they're working to release a fix soon. I'm sorry you're having this inconvenience and my best advice is to visit this thread in order to receive updates about this matter. Please know your feedback will be passed along to our team.
@Latrru Thanks for keeping the Fitbit app updated. I'm glad this got sorted out and I hope you can keep crushing your goals.
05-02-2022 00:05
05-03-2022
11:52
07:11
05-03-2022
11:52
07:11
Hi there, @RebelReynolds.
You're welcome, thanks to you for the time taken while troubleshooting your Charge 4. We'll keep updating that thread as soon as we have more details from our team. If you have any other question, you can always create a new thread to receive help from the Community.
01-08-2023 10:05
01-08-2023 10:05
This is brilliant!!!! I've just spent hours trying to get my charge 4 to sync; and reconnect to Bluetooth.
This took awhile, but it worked, thank you so much!
02-04-2023 20:33
02-04-2023 20:33
My Charge 4 was connected via the app to my Galaxy Note 20 Ultra. It was taking forever to sync so I uninstalled the app and reinstalled it. Now I cannot get my Charge 4 to connect to the app on my phone. I’ve rebooted the Fitbit, force stopped the app, turned bluetooth on my phone off/on, rebooted my phone and still nothing. The app is updated. There are no other bluetooth devices in close proximity that are interfering with the Fitbit connection. I get to the step where I enter the 4 digit code generated by the Fitbit into the app and it just hangs. Get the message that “Sorry, the setup is taking longer than usual. Please be patient. We’re on it!” Well, after screwing around with this for over an hour, I have no flipping patience left! I don’t want to reset my Fitbit because I will lose a week’s worth of data. My Fitbit used to auto sync but that stopped working months ago. Every time I go in to manually sync, it takes forever and I usually have to close the app, reopen it and sync again.
02-12-2023
13:05
05:57
02-12-2023
13:05
05:57
Hi there, @Norcal_lisa.
Thanks for the detailed information and your efforts while working on this matter. I'm sorry you're having this experience with your Charge 4. Because it's been a few days since you shared this situation, may I know if your tracker is now syncing? I understand you've tried troubleshooting your tracker, but please make sure to have checked the requirements and exhausted the steps described in this help article.
02-16-2023 15:24
02-16-2023 15:24
I tried everything in the help article and I am still unable to connect my Fitbit. I posted this yesterday but thought you might not have seen it so I am posting it in this message.
I am having exactly the same problem. My Fitbit last synched on January 27. Since then when I try to synch it stops with the blue line about half way then times out. I have tried all of the things Norcal_lisa has. I get the same circling message saying it’s connecting but it times out and says something went wrong. Please help!!!
02-17-2023 04:24
02-17-2023 04:24
