01-30-2024
01:32
10:23
01-30-2024
01:32
10:23
Charge 4, iphone SE 2020, phone&app utd.
After charging last night, time on the tracker was off by 54 minutes. Tried syncing without any luck.
So far I have done this:
-rebooted tracker while charging
-tried tricking it by installing new clock face from app. That worked, but still won’t sync
-removed tracker from app and phone
-rebooted tracker from it’s «settings» menu
-cleared all user data from the «settings» menu on tracker
- tried a number of times to reconnect tracker. It is found, and I get as far as entering the four digit code, from there it just stops.
Tracker bought may-22, activated first time early june.
Have had problems syncing for a while, but it always has been sorted out by removing/re-adding/rebooting. This time nothing happens.
sent an e-mail via form to customer service regarding guarantee, but didn’t get any confirmation it was sent.
02-11-2024 15:07
02-11-2024 15:07
Normally with a time issue
Best Answer02-12-2024 11:55
02-12-2024 11:55
@Rich_Laue Thank you for your help and recommendations.
@Mallilen , A warm welcome to the Community !Thank you for your message and efforts.
Make sure there are no other Bluetooth devices connected to the phone or nearby. (headphones, keyboards, etc.)
Please follow these steps, some you have already done, but the order is important:
Best Answer02-22-2024 09:22
02-22-2024 09:22
Hi @JuanFitbit
I have the same issue with my Charge 4 and my iPhone 8. I did all the steps and nothing worked. (Multiple times)
What can I do else?
Best Answer02-26-2024 10:08
02-26-2024 10:08
@UweT , A warm welcome to the Community! Thank you for your message and efforts.
Do you have access to another mobile device? (eg, borrowed from someone, or an older device, where you could install the latest Fitbit app?
If so, install the Fitbit app on the alternative mobile device. Log in.
Turn the Bluetooth off of the iPhone 8.
Try setting the Charge 4 on the alternative device and your account.
Once the Charge 4 is connected to your account.
Turn the Bluetooth of your alternative device off.
Turn the BT of the iPhone 8 on.
Open the Fitbit app on the iphone 8.
Try to sync the Charge 4 with the iPhone 8
