09-09-2022
13:13
13:52
09-09-2022
13:13
13:52
Charge four not connected in blue tooth.
09-12-2022 10:57 - edited 07-15-2023 03:54
Hi there, @dianewithdogs. Thanks for stopping by in the Community Forums.
If you haven't done so yet, please follow the tips and recommendations provided here Why won't my Fitbit device sync?
Best Answer09-10-2022 07:55 - edited 09-10-2022 07:55
Hi there, @Gute. Thanks for stopping by in the Community Forums and sharing the details about the issue with your Charge 4.
If you haven't done so yet, please try removing the Bluetooth connection between your phone and your Fitbit device:
*On your phone, tap Settings > Bluetooth > the information icon next to the name of your Fitbit device > Forget This Device.
*Open the Fitbit app and set up the connection again. You should receive a message asking you to allow your Fitbit device to pair with your phone. Tap Pair to approve the request.
Sync your Charge 4 automatically when you open the Fitbit app or manually by tapping your profile picture > your device tile > Sync Now.
If the issue persists, see Why won't my Fitbit device sync?
Hope that helps.
Best Answer09-10-2022 08:20
09-10-2022 08:20
Best Answer09-10-2022 08:48
09-10-2022 08:48
@Gute Thanks for getting back and for the details provided.
Please try the following steps in the order shown:
If you can't get started with your Charge 4, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Hope this helps.
Best Answer09-10-2022 09:50
09-10-2022 09:50
Ever since doing the update last Thursday, no sync
Best Answer09-12-2022 10:57 - edited 07-15-2023 03:54
