05-10-2023
05:32
06:50
05-10-2023
05:32
06:50
Hi
I've been having this problem for a few days in that my Charge 4 won't synf to my android (Samsung). In looking at other posts, the recommendation to restart the FitBit, and then also restart the app isn't working. I've also tried disconnecting from WiFi and syncing that way but also doesn't work.
Any suggestions?
05-10-2023 06:52 - edited 05-26-2023 11:37
Hi there, @HomeTerra. Welcome to the Fitbit Community Forums. Thanks for trying to troubleshoot the issue with your Charge 4 before reaching out.
In addition to the steps you've done, please try the following steps:
Best Answer05-10-2023 07:37
05-10-2023 07:37
Hi @MarreFitbit
Thanks for the prompt reply. This seems to have worked and the FitBit app is now showing data from my Charge 4. I'm not entirely convinced it will retain the sync though, as it didn't seem to 'connect' properly. I had to close the app (whilst it still said Connecting, after entering the pairing code), and then when I opened it, it had synced / paired. So will keep an eye on it.
I also note that the time on the FitBit is way off (30 mins). I'm hoping this will be resolved when I connect to the GPS and it starts pulling the time automatically.
For now, it seems to have worked, so thanks again!
Best Answer05-10-2023 12:31
05-10-2023 12:31
Hi again @MarreFitbit
As I thought these steps didn't work. I've updated the FitBit app, gone through the above steps again, and it simply won't connect when I enter the pairing code.
Many thanks
