03-28-2022
08:08
14:39
03-28-2022
08:08
14:39
very tired of my charge 4 not sycing to the app or doing it then de sycing in a few minets or days, for past 5 months my charge 4 has rnadomlly de syncied with the app, started running slow time wish then just as randomly re sycyng with the app, Iv done all the trouble shotting steps, reset both my phones bluetuth and the charge 4 but nothing lasts more than few days befor it off line and just tracks my steps but does not send to y phone or keep prober time
04-01-2022 04:18 - edited 03-19-2024 08:58
@Mjhyde13 Thanks for the details provided in your previous post. I understand where your concern is coming from.
I'm glad to hear that your Charge 4 finally synced. However, if you continue having syncing difficulties, please try following the tips and recommendations I've provided here.
See you around.
Best Answer03-31-2022 14:27 - edited 03-19-2024 08:59
Hi there, @Mjhyde13. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Charge 4 before reaching out. We‘re taking your comments and sentiments in regards to our products into consideration.
May I know the model of your mobile phone? Please make sure it meets the requirements listed here.
Despite meeting the above requirements, the following devices often exhibit compatibility issues that cause our products and services to not operate properly:
If your phone is not on the list above and meets the requirements to operate properly with the Fitbit app, please try the steps provided above:
1. Remove the Charge 4 from your phone's Bluetooth settings and in the Fitbit app.
2. Restart your Charge 4.
3. Turn off other Bluetooth connections when not in use.
4. Plug it into the charging cable and open the Fitbit app.
5. Set up your Charge 4.
Hope that helps.
03-31-2022 18:34
03-31-2022 18:34
Best Answer04-01-2022 04:18 - edited 03-19-2024 08:58
See you around.
Best Answer06-06-2022 12:09
06-06-2022 12:09
IM done I sat my fitbit on my phone over night and ut syncned, less than 2 hours waring it it desynced and lost over an hour of time as in Phone says 3:08 pm right now fitbit says 2:43, dont know if its a phone issue or a blutooth issuee but Im tired of it
Best Answer06-10-2022 06:23 - edited 03-19-2024 08:58
@Mjhyde13 I'm sorry to hear you're still having issues with your Charge 4. I understand how you must be feeling and I really appreciate you had followed the tips and recommendations provided above.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
Best Answer08-18-2022 08:23
08-18-2022 08:23
Thanks! My charge 4 was slow to sync but this did it.
I used charging cable to restart it.
08-18-2022 16:33 - edited 08-14-2023 10:18
Hi there, @maxerbubba. Welcome to the Community Forums. I'm glad to hear that the steps recommended did the trick. 🙂
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
