08-06-2022
02:04
14:01
08-06-2022
02:04
14:01
My fitbit 4 won't synch on my phone. When I go to add a new device ,( its not but I've tried everything else I think ,) it says there is a device already there i turned phone off and on same with Bluetooth.. how should it show in Bluetooth as I cant see anything there apart from DB whatever that is
08-06-2022 06:17 - edited 12-22-2023 03:35
Hi there, @shazza1962. Thanks for stopping by in the Community Forums and trying to troubleshoot the issue with your Charge 4 before reaching out.
May I know the model of your mobile phone? Please make sure it meets the requirements listed here.
Despite meeting the above requirements, the following devices often exhibit compatibility issues that cause our products and services to not operate properly:
If your phone is not on the list above and meets the requirements to operate properly with the Fitbit app, please try the steps below:
1. Remove the Charge 4 from your phone's Bluetooth settings and in the Fitbit app.
2. Restart your Charge 4.
3. Turn off other Bluetooth connections when not in use.
4. Plug it into the charging cable and open the Fitbit app.
5. Set up your Charge 4.
Hope that helps.
Hope that helps.
08-06-2022 06:20
08-06-2022 06:20
Thank you. I worked out it was connected to my ipad and so was picking up there instead .. technology eh !Thanks for replying
08-08-2022 05:14 - edited 06-28-2023 10:07
@shazza1962 Awesome! I'm glad to hear that you managed to solve the issue.
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
