03-29-2022
05:25
14:39
03-29-2022
05:25
14:39
I don't know why, but 1 days of 7 it doesn't take my sleep score, sometimes for 2 days consecutive.
I tried many time to reset it and restart my phone but it happens again and frequently. I never changed anything else and it is on my wrist in the same way, not too large and not too strong. So, what is the problem? I am near also to renew my subscrition but now I am not sure to do that if I can't see my score every night. it is very annoying!
03-31-2022 14:03 - edited 11-13-2023 04:23
Hi there, @Belthazor69. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Charge 4. I understand where your concern is coming from.
Keep in mind that you must see sleep stages in order to see your sleep score information. Please swipe left on the Sleep Score graph, here you can see information about your weekly sleep average and sleep duration. To get more detailed information, see What's sleep score in the Fitbit app?
With that said, I recommend considering the following in order to get sleep stages:
For more information, see What should I know about Fitbit sleep stages?
Hope this helps.
04-01-2022 04:53
04-01-2022 04:53
Well, for the first point i don't think to have change my position to sleep and I never change how I wore my Fitbit. The fact is that happens for a few weeks and I never missed a sleep track . The sensors are always in contact with my skin, there is no space anytime from the sensors and my skin and is not too tight . Anyway i will try to follow your instructions and see what happen then. Only the weird things is that I never changed anything.
04-01-2022 05:42
04-01-2022 05:42
@Belthazor69 For sure! Give it a shot and let me know if something changes. I'll be around and glad to continue helping you. 🙂
04-01-2022 08:33
04-01-2022 08:33
I will do! Thank you so much.
04-04-2022 12:16
04-04-2022 12:16
Hello I have this same problem. It shows my sleep scores approximately once a week on a random day. I've checked all the points here. There's no obvious reason. Any clues? It's really annoying! NB the app is up to date. Thanks
04-04-2022 14:31
04-04-2022 14:31
Same problems. Must be an issue with fitbit
04-05-2022 23:43
04-05-2022 23:43
Charge 4. Won’t monitor sleep pattern.
did it four times from new. Now stopped.
There is obviously an issue with them from looking at previous comments.
same stock answer from the moderator.
I will give it another week then I’m returning it if it doesn’t work.
also noted the battery is losing power quickly.
04-07-2022 10:12
04-07-2022 10:12
You need to see sleep patterns to get a sleep score.
You need 3 hours of sleep and a consistent heart rate reading to see patterns.
Open The fitbit app, go to the night in question.
Look under the graph, fitbit may already have toodgyou what went wrong.
04-07-2022 10:25
04-07-2022 10:25
Hi Rich.
it worked for four nights. No problems.
Doesn’t record details.
Having looked at the forum, it appears to be. Common issue.
04-07-2022 12:12
04-07-2022 12:12
So what does your app say @1105pah
04-07-2022 12:28
04-07-2022 12:28
I've checked all the tips and followed the advice and also contacted fitbit help who told me to reset the device. But it still will only give me basic sleep stage info.
My heart rate is consistently measured, I'm sleeping for more than 3hrs and I'm not doing any of the other things it warns of. It's clearly a bug as so many people are affected but it's very annoying. My old Alta HR did it fine and gave me a sleep score every day!
04-07-2022 12:40
04-07-2022 12:40
It’s not what it says. It’s what it doesn’t say.
No score. No breakdown on sleep pattern.
it had done it several times. Then stopped.
Others as per post have had same issues
04-09-2022 17:08 - edited 04-10-2022 14:43
Common issue indeed and quite frustrating that Fitbit can't figure this out. I've again seen this issue over the past week where a Sleep Score isn't provided and is typically associated with missing sleep stages. I'm not doing anything different and this is a repeat problem that crops up every couple of months. Disappointing as the sleep information is most important to many and Fitbit can't reliably provide.
