02-25-2023
02:58
10:23
02-25-2023
02:58
10:23
Two nights ago I went to check my Fitbit and it would turn on and the screen was black. I thought it must be out of charge so I put it on the charger overnight. In the morning it still wouldn’t turn on and on the Fitbit soo it still said it was on 11% and was still tracking my steps and heart rate. I’ve had my charger 4 for three years and this is the first time this has happened.
Update: I meant to say Fitbit app*
04-13-2023 01:24
04-13-2023 01:24
If your Charge 4 won't turn on, here are some troubleshooting steps you can try:
Check battery level: Make sure your Charge 4 has enough battery power. If the battery is drained, you may need to charge it before it will turn on. Connect it to a charger and let it charge for at least 30 minutes.
Try a different charger and cable: Sometimes a faulty charger or cable can prevent your Charge 4 from turning on. Try using a different charger and cable to see if that resolves the issue.
Check for physical damage: Inspect your Charge 4 for any physical damage such as water damage, visible cracks, or other signs of damage. If there is any physical damage, it may be preventing your Charge 4 from turning on.
Restart your Charge 4: Press and hold the button on your Charge 4 for at least 8-10 seconds until the Fitbit logo appears. This will perform a hard reset on your Charge 4 and may help to resolve any software issues.
Regards,
Diana
Best Answer02-25-2023 05:04
02-25-2023 05:04
I have the same issue. My isn’t turning on at all despite charging it all night with the Fitbit cable (I didn’t use a different kind). I got it three years ago, can the battery be dead already?
02-25-2023 10:26 - edited 02-25-2023 10:28
Hi there, @Milo_267- @Nikalis. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Charge 4 devices before reaching out.
I've seen you contacted our Support Team after posting here and they've already assisted you. If you still need help or have any questions/concerns regarding the outcome of your case, please feel free to contact our team back for further assistance.
I hope we can et you back on track soon.
Best Answer02-25-2023 15:03
02-25-2023 15:03
My charge 4 still isn’t working
Best Answer02-25-2023 17:19
02-25-2023 17:19
Mine is doing the same thing right now!!!! It says 83% charged but dark screen until I attach to charger then it shows a smiley face then I can detach charger and im able to scroll screen however while it was unresponsive it didn't collect my hard earned steps!!! I compete with myself to get steps in and **ahem**it I thought my charge was just a goner... I see multiple people having this issue with charge 4 in the last 24 hours is it a software issue??? Please help me keep my new found favorite motivator motivating😁 I have come to love my charge 4, at the moment I'm spending too much time trying to get it to work. Any body solved this issue yet??? Thank you
04-10-2023 19:55
04-10-2023 19:55
I have the same problem. Please help.
Best Answer04-11-2023 22:14
04-11-2023 22:14
I’m having the same problem.It definately isn’t the battery. Just rebooted my Charge 4 and hope that will fix the issue. Does anyone else have any tips?
Best Answer04-12-2023 10:20
04-12-2023 10:20
Best Answer04-12-2023 14:19
04-12-2023 14:19
Thanks! I’ll try that as rebooting didn’t work.
Best Answer04-13-2023 01:24
04-13-2023 01:24
Regards,
Diana
Best Answer06-24-2023 05:15
06-24-2023 05:15
I am having same issues and the restart is not working, my charge 4 is dead]
Please reply, thanks
Best Answer06-24-2023 13:37
06-24-2023 13:37
@merquilts Welcome to the forums. I will be happy to help you get your Fitbit Charge 4 running again.
Thanks for the initiative to solve this on your own. In case your device is not responding, I recommend you take a look at the tips in the following article: Why isn't my Fitbit device's battery charging?. There is a tip for every possible scenario. Give it a try.
