04-30-2023
13:57
07:08
EstuardoFitbit
04-30-2023
13:57
07:08
EstuardoFitbit
I charged my Charge 4 to 100 % this morning. 2 hours ago it was dead and I cannot wake it up. Putting on the charger does nothing. It will not even charge.
Moderator Edit: Clarified Subject and label
05-01-2023
08:04
11:59
05-01-2023
08:04
11:59
Hi @DonDIego2, welcome to the community.
I just moved your post to "Other Charge Trackers" to keep the community organized. I want to know if you have tried restarting your Charge 4?
Best Answer05-01-2023 10:19
05-01-2023 10:19
This happened to me too - my Fitbit was ok this morning and now won't turn on and won't charge, it is completely dead. I've tried your suggestions and it doesn't make any difference. Does it need a new battery?
05-02-2023 04:55
05-02-2023 04:55
The same thing is happening to me. Sunday night I charged to 100% and Monday night I noticed the battery was dead. I tried charging, it went from 81% to 0% in minutes. What is going on?
05-02-2023
07:55
11:59
05-02-2023
07:55
11:59
Hi @JudithFere, @RainyP, thank you for taking the time to share your comments and updates. A warm welcome to the new members.
Based on the information provided, I recommend taking a look at this article "Can I extend my Fitbit device's battery life?", since there are several factors that could affect the battery life of your device.
I also recommend checking if you are missing any firmware update for your devices. Please follow these instructions "How do I update my Fitbit device?" to check for updates.
Best Answer05-02-2023 11:19
05-02-2023 11:19
Hi there.
I'm not new to FitBit (2015) and this is not my 1st technical issue. It will be my last, I won't buy another one just so that it's replaced in less than a year and the the replacement gas the same issue of the replaced tracker. That makes no sense and it bad business. The 1st article is not helpful to me.... I was only charging my battery once a wk until yesterday. Please provide the latest firmware information so that we know what it should be.
Thanks!
Best Answer05-02-2023 20:37
05-02-2023 20:37
My charge 4 has also suddenly 'died' with no notification that the battery was low. Twice in one day - the second one 7 or 8 hours after I charged it. I have to reboot my charge 4 frequently due to GPS issues (since July 2022), but this is a new problem. Been a loyal customer since 2017, seriously thinking about leaving now.
Best Answer05-03-2023 01:06
05-03-2023 01:06
You may need to restart multiple times or alternate charging and restarting the device. Fitbit might need a restart to get to a point where it can accept a charge, but it might not yet be recovered enough to turn on. Perform a factory reset of the Fitbit.
Regards,
Will
05-03-2023 01:15
05-03-2023 01:15
Best Answer05-03-2023 08:31
05-03-2023 08:31
I have tried everything. It does not vibrate. I cannot restart it. When I leave it on the charger it just gets warmer but is still dead with no vibration if I press the side or attach the charger.
I threw it in the trash yesterday and deleted my app.
Using my Garmin to track steps since you no longer support challenges, I don't need a Fitbit.
13:41
11:59
05-03-2023
13:41
11:59
Hi everyone, @willjoe. Thanks for helping out!
Thanks for letting us know about your Charge 4 battery issue and the steps tried on your own. I understand how you're feeling, and I believe we could give you a suitable resolution if you contact our Support team. I'm sorry for any inconvenience this has caused, and your feedback is truly appreciated.
