11-28-2021
17:53
16:06
11-28-2021
17:53
16:06
I do not know if my Charge 4 is still under warranty. It was shipped Jan 2021. But the connection for the wrist strap just broke off without any known stress. Is there any way to repair this? I tried super gluing it back on but obviously did not get is back together well because the band will not stay connected.
12-30-2021
10:24
11:13
EstuardoFitbit
12-30-2021
10:24
11:13
EstuardoFitbit
same problem here
Best Answer12-30-2021 11:53
12-30-2021 11:53
Same. This is a known issue for the Charge 4s and they won't do anything to help customers.
12-30-2021
18:51
11:14
EstuardoFitbit
12-30-2021
18:51
11:14
EstuardoFitbit
It’s too bad Fitbit can’t make a quality product they can stand behind. When I spend $150 on an item I expect it to last for a while. My band broke off after 14 months. That part clearly needs to be metal, not plastic.
I’m thinking about Garmin too. I’ve had a Fitbit for at least 7 years. This one lasted 14 months.
Moderator Edit: Merge replies
12-30-2021 21:31
12-30-2021 21:31
I can't believe they continue to sell the without addressing this issue
01-22-2022 18:37
01-22-2022 18:37
My charge4 band connection also broke off after using it for a little over a year. The connectors in Charge4 were plastic and bad design. Is Fitbit going to do the honorable thing and send a replacement out of warranty or am I SOL! Seems like a known and documented problem. Thanks.
01-23-2022 18:10
01-23-2022 18:10
From what I've seen thus far all they have offered after a year was a small discount on another Fitbit product. I tried another brand and didn't love it. Picked up a Fitbit versa from Costco for $149 CAD and was happy to see it has a different strap attachment with a pin which should be better.
18:15
13:47
EstuardoFitbit
01-23-2022
18:15
13:47
EstuardoFitbit
I ended up getting a Charge 5 at Costco, they completely re-designed the band. The Costco bundle gets you two different bands which I also liked. And at least Costco stands behind the products they sell. Correct, FITBIT offers 35% discount but not off all the trackers, and not on any that I wanted. I hope you love your new purchase!
I hope my new Charge 5 from Costco lasts longer than 14 months.
I guess they do not care about the customers who are loyal to them and wear their Fitbit often. I noticed that the directions now say to take it off from time to time. I love using mine to track my sleep.
05-27-2022 11:46
05-27-2022 11:46
Were you able to fix it?
11:50
11:14
EstuardoFitbit
05-27-2022
11:50
11:14
EstuardoFitbit
Nope
Moderator Edit: Removed personal info
11:53
11:20
DavideFitbit
05-27-2022
11:53
11:20
DavideFitbit
I have an option to get a new Charge 4 Replacement for free or get 50% of another watch, and I am considering Charge 5. Another post said the Charge 5 has the same problem, but you say the bad design was corrected. Is this correct?
Ok thanks!!!
Best Answer05-27-2022 11:59
05-27-2022 11:59
Best Answer05-27-2022 12:18
05-27-2022 12:18
Best Answer12-02-2022 20:39
12-02-2022 20:39
Same here. My wife has now had three fitbits break in that same way - the plastic bits on the case that allow the band to affix to the watch unit and I have had two break that way and one that failed due to a fading display. None were under warranty. Once I got $50 credit on the purchase of a new one. No more. Kind of tired of paying ~$100 per year for a fitbit. Now going to try one of these I think https://us.amazfit.com/products/amazfit-gts-4-mini .
My last one was purchased late Aug.2021 and broke today 12/2/2022 so life of 15 months. Sounds like what a lot of other have experienced. So we have multiple fitbits that COULD still function if they could fit inside of a differently designed band.
From a companies standpoint, it's a nearly perfectly designed product in that it fails just past warranty necessitating a new one or a change. I don't really want to change but then again, how can I look at myself in the mirror AND buy yet another one.
02-08-2023
11:16
08:32
DavideFitbit
02-08-2023
11:16
08:32
DavideFitbit
I am on my second fitbit Fourth because of other issues) for the same reason, previously I have had to get new straps. I think by now I am out of warranty. This is pathetic. I am now researching a more reliable product, if anyone has any advice, I would be glad to hear it. I definitely won't be buying fitbit again.
I think you are lucky to be getting a replacement.
Best Answer02-08-2023 12:03
02-08-2023 12:03
Best Answer02-08-2023 12:24
02-08-2023 12:24
Best Answer03-06-2023 06:16
03-06-2023 06:16
Fitbit did eventually replace my Charge 4, but the band on the replacement unit failed last week. Since it is no longer under warranty, I tried the super glue again. It is working great. So if you cannot repair your band connection, I suggest cleaning it well and applying super glue.
Best Answer03-06-2023 10:25
03-06-2023 10:25
Best Answer05-22-2023 20:46
05-22-2023 20:46
I have the same problem the clip on the watch head broke after I replace the band twice for a different issue.
Best Answer05-31-2023 08:10
05-31-2023 08:10
It's the screws in the mechanism. They get corroded and break off. A really bad design flaw for a product that is supposed to be water-resistant.
