01-28-2022
08:02
15:46
01-28-2022
08:02
15:46
I have the Charge 4 for about 1 year or so. The plastic connector on the watch face breaks so that band can no longer connect. I contacted Support and they emailed me back a 35 percent discount. I called back and they told it was outside warranty. After spending $150 on this Fitbit, this is the only thing they could offer?
01-28-2022 12:25
01-28-2022 12:25
Mine broke after 13 months. Customer service was useless. I bought a band off Amazon with a pocket to hold the tracker so I can use it. Look up goseth charge 4 bands. Cost about $12.
01-28-2022 13:08
01-28-2022 13:08
Will the goseth band work if the connector broken off the watch face tracker?
That connector was glued on with two tiny pieces of plastic. Very disappointed with this quality and lack of service.
01-28-2022 13:21
01-28-2022 13:21
Yes there is a picket that the tracker fits in. Not very attractive but at least you can use it. Fitbit is dropping the ball and will be losing customers. Expecting customers to buy a new watch due to their defective product is unacceptable
01-28-2022 13:21
01-28-2022 13:21
That should be pocket.
Best Answer01-28-2022 13:26
01-28-2022 13:40
01-28-2022 13:40
Thank you!! Your response is a lot more helpful than their Customer Support. I will definitely check out this band.
01-28-2022 13:51
01-28-2022 13:51
Thank you for this useful tip. Mine also just broke. I have had it for about 14 months. I had noticed the watch band would come unattached when it got bumped hard. I just figured it was because the watchband was a cheep aftermarket replacement. Now I wonder if the connector was giving out before it actually broke off.
Best Answer01-31-2022 06:38
01-31-2022 06:38
Yes mine started to to break away after 18 months and definitely a design issue, should be a one piece unit.
Spoke to Deiby R at customer service, he refused to review my pictures and emailed me next day stating out of warranty and gave the standard discount,that means every 18 months need to replace the watch. I also asked to speak with management or Customer Care .he said You-are speaking to him.!
The worst customer service experienced,I will NOT be purchasing another Fitbit product.
01-31-2022 06:41
01-31-2022 06:41
Hi, mine did the same as many users are experiencing,where did you purchase this band.currently using a rubber band to track my sleep.
01-31-2022 07:56
01-31-2022 07:56
Look on amazon for goseth charge 4 band
02-01-2022 05:05
02-01-2022 05:05
Thanks just ordered one. Better than buying a new fitbit
02-01-2022 05:20
02-01-2022 05:20
Fitbit could have taken the high road and developed a solution to keep charge 4 owners happy. But sadly they have decided to ignore us.
Best Answer02-01-2022 09:19
02-01-2022 09:19
Best Answer02-01-2022 12:46
02-01-2022 12:46
Update: Thanks to your tip. I purchased the same goseth band from Amazon. Just started wearing it today. It works well.
I’m still hesitate to purchase any more Fitbit products because of the quality and lack of customer service.
Best Answer02-01-2022 14:48
02-01-2022 14:48
