03-21-2016
18:01
20:15
03-21-2016
18:01
20:15
Hi There. My fitbit charge HR is onle 7 months old and it (for some reason) has stopped working.
I charged it last night, put it on this morning fully charged, checked the time at 830 ish and the time was off by about 25 mins. I synced to my android phone app and the time corrected itself on the fitbit. Not even a half hour later i tried again to check the time - it only had the fitbit logo and the version number (122) then went blank again. As of noon or so today I can even get the fitbit to turn on or show anything on the screen. The heartbeat monitor light isnt even on and now I cant connect to it via bluetooth or via the cord.
Please advise how to correct this asap
01-23-2017 11:43
01-23-2017 11:43
Well it has been a couple more weeks of frustration now with my Charge HR. It wasn't working (counting steps or mmeasuring pulse) so put it on the charger connected to the PC. Showing that it was 3/4 charged. I just let it sit there and the green LEDs flash twice, then one more time then I see V122 on the display. About 30seconds later it flashes agian repeating the same as before. Then a third and fourth time. I never touched it. Just watched these resets repeat. Then 45 minutes later I checked and it was charged up. Put it on walked around, step count = 0. Wonderful, great device. Did the recommended resets 4 times on the charge cable. Then worked for 14 hours and the battery was dead.
Charged again, reset again and it worked for 2 days and battery dead. Charged and rest worked sort of. Counts about half the number of steps it used too. I walk with my wife and her Alta which we compare step counts with. Used to have about the same. Now I have less then 1/2 her count. Also less then 1/2 the stair count.
Suggestions on fixing this thing? Or a replacement? This Charge HR is about 10 months old now. Did not think I will buy another Charge HR.
01-23-2017 18:50
01-23-2017 18:50
how frustrating! These things shouldn't happen to 8-, 10-mo. old products costing over $100.
13:58
04:19
JuanJoFitbit
01-24-2017
13:58
04:19
JuanJoFitbit
And it continues, walked a block to the mail box this morning which is easily 200+ steps and checked my Charge HR to see it counted about 40 steps. Not working as ity should. Does seem to keep track of my heart rate correctly.
The latest now that tge tracker has died. I charged it up and watched it repeatedly reset. By that I watchex the geern LEDs flash a couple times then the display would flash the Fitbit logo with V122 just barely long enough to see what it was. Then repeat. This went on 10 12 times until I pressed the button and held it in. It did one more reset and the V122 displayed and stayed so I let up the button. Counted 6 steps all day with my walking blocks. Never did show my pulse, only --. I would say it has died now. Only 10 months old.
Moderator edit: merged reply
Best Answer01-29-2017 05:15
01-29-2017 05:15
03-20-2017 18:12
03-20-2017 18:12
Similar issue here. My hr charge display doesn't work except for occasionally the version screen that pops up when I do this solution. I have tried several times and I'm not having any luck.
any other ideas?
Best Answer03-21-2017 09:32
03-21-2017 09:32
Best Answer03-22-2017 06:45
03-22-2017 06:45
I already did. Was out of warranty by a week and they wouldn't help. Was disappointed in the lack of customer service after I had purchased two of these for our family if I can't get it working I won't buy anything else from Fitbit. hoping to fix it
Best Answer04-18-2017 23:31
04-18-2017 23:31
Ditto, I have the same issue
Best Answer06-06-2017 07:03
06-06-2017 07:03
I feel the same as you and I only got offered a 20% discount. From reading this thread it seems that this product has many problems.
06-06-2017 23:39
06-06-2017 23:39
Best Answer06-07-2017 03:57
06-07-2017 03:57
The plastic band covering on my replacement HR has started to separate. It suddenly blushed up. It is a year old this month. I know at least 3 others that are having the same problem.
Best Answer10-25-2017 04:47
10-25-2017 04:47
I pushed the button to turn on notifications since they had stopped working and the screen went blank and won’t come back.
90% charged ifhooked to cable battery symbol comes up
Best Answer10-25-2017 05:41
10-25-2017 05:41
Best Answer10-25-2017 17:41
10-25-2017 17:41
10-25-2017 17:48
10-25-2017 17:48
Best Answer10-26-2017 05:47
10-26-2017 05:47
Best Answer10-26-2017 07:53
10-26-2017 07:53
Best Answer10-26-2017 08:28
10-26-2017 08:28
Best Answer10-26-2017 13:56
09-30-2018 02:28
09-30-2018 02:28
My charge hr stopped working And a green light is also not working it was the second time but it was not working and it was not charging also so I want to reason why It stopped
