07-18-2016
17:28
20:15
07-18-2016
17:28
20:15
07-26-2016 06:01
07-26-2016 06:01
Hi @fastfist99, welcome to the Community!
Hmmmm, the behaviour of your Charge HR sounds very weird. It seems that is more than a display issue, is also having battery draining issues which are affected by the constant resetting and the lights flashing almost all the time.
I appreciate you have tried to restart your tracker, but as it hasn't worked, I suggest you to get in touch with Fitbit Support directly, so they can take a look into your account and find the best solution for you.
Let me know what they say about this. ![]()
07-26-2016 06:01
07-26-2016 06:01
07-26-2016 11:50
07-26-2016 11:50
07-27-2016 05:37
07-27-2016 05:37
You are more than welcome @fastfist99! I knew that Fitbit Support will help you out with this and get you back on track with a new Fitbit.
If you need help to set it up, don't hesitate to let me know.
Have a great day!
08-09-2019 12:08
08-09-2019 12:08
Have same problems as another user, fitbit works fine, But bright green lights , they were flashing, now just bright green, Battery is draining fast.
Best Answer01-26-2020 03:47
01-26-2020 03:47
would it be a good idea to replace battery or is problem something other electrical?
Best Answer01-26-2020 03:58
01-26-2020 03:58
is it an idea to replace battery or is it something else electrical?
