Charge HR calorie burn accuracy
ANSWERED
I have just started using my Fitbit and it is telling me that I am burning in excess of 3500 calories a day but I'm not sure how accurate this is. I'm aged 25, 5t 9in and around 75kg. I have a fairly active job which involves me walking close to 20,000 steps a day and also partake in 1-2 hours of fairly intense exercise per day.
30 REPLIES 30
Not sure how to reply to the thread as a whole so I'm replying here.
I'd guarantee that the calories burned calculation on these devices is way off. If I look back over my data I'm consistently eating 8 - 900 calories a day less than fitbit is suggesting. And I'm maintaining sometimes gaining weight if I use this device as a dietary guide. Example - I sit at a desk all day and my BMR calculates on fitbit to be around 1900 calories a day.... That part seems legit. I walk 14000 steps taking the dog out. Calories burned rockets to near 4000. Theres no way that's accurate for a very gentle walk over the course of 90 minutes. I think the issue is to do with where fitbit has set the "fat burning zone" on the heart rate monitor. You can tweak this manually which I've done tonight do hopefully that will help. I'll let you know how I get on
How did you get on with tweaking the fat burning zone heart rate? I've only just got a Fitbit (because I need to lose weight/get fitter) and reading these threads is making me anxious to make my Fitbit as accurate as possible as I'm past the point of being able to return it.
If anyone has any other advice I'd appreciate it 🙂
Fitbit is completely inaccurate. Ive just bought the charge 5 and according to this calories i burn, i would wittle away in no time.
Why are they so inaccurate?
Great Video!
Thanks for the post!
Your body can burn minimum of 1200 calories a day depending on height and weight etc when just lying in bed or sitting on the sofa binge watching friends. I'd say that's pretty accurate. I wouldn't worry too much
That isn't strange in the slightest. your body burns quite a few calories just my functioning properly. I really wouldn't over think that. My personal trainer said to me it's very possible to burn a decent amount of calories when asleep
It's really not excessive
Not totally true. Once you've gone through all your calories in a deficite, you've used up all your glycogen stores so then your body is forced to use fat. It's all in the deficite. However, eat whole carbs- not refined ones- because the sugar crash 2 hours after the refund carbs will make you super hungry and eat more more needed. However, whole carbs (paired with healthy fats and protein) keep your glucose levels stable, your appetite steady for longer, therefore naturally eat less. Enjoy the pizza my friend on a Friday night
Your body is burning calories all day everyday. You burn calories for your body to function so yes while you are sleeping you continue to burn calories and your Fitbit will of monitored this. I have not long woke up and I have burned 700 calories in my sleep. The human body burns around 1800-2000 cals depending on your size, age gender etc a day without activity for it to function. The more active you are the more you burn those calories. I do around 20,000 steps a day and I swim on some of those days also. I burn about 3300 calories. If I did nothing all day I would still burn those 1800-2000 calories a day but if I chose to eat more than that then I become fat. If I chose to eat less than that I would become thin. If I chose to eat that daily amount of calories, did no activity at all my weight would remain the same which is why some people just forever maintain their weight with no exercise at all. I’ve seen a few people wonder how they are burning calories in their sleep, your body has to get energy from somewhere to function as even sleeping your body has work to do,
The human body burns around 2000 calories a day without any activity, it is how the human body functions. This is why we are set that amount of calories a day to consume. 2000 for women and 2500 for men. Every part of your body burns calories to function and when you are asleep your body still needs to burn calories to keep your heart and lungs going and everything else. If you consumed 2000 calories a day, did no activity at all you would maintain whatever weight you are as you are only consuming what your body needs. If you are consuming more than this in a day and still doing no activity then you will start to gain body fat or loose body fat if you are under eating those calories. People who exercise a lot have to consume more calories in a day as their body will struggle to function and become very hungry and if they wanting to just maintain their weight they can eat the amount of calories they have burned. So I burn around 3300 cals a day, if I want to maintain I could eat that amount of calories but I need to lose fat so I make sure I have a 750 deficit on a daily basis and consume around 2500 cals to keep my body going for my activity levels and I lose 1.5 pounds of body fat weekly. I still get  hungry sometimes even on 2500 calories as I’m burning 3300 but I must lose body fat and try to consume food that keeps me fuller for longer. When I woke up my body already burned 750 cals in my sleep as my Fitbit knows my activity levels and calorie consumption, weight etc etc.
Nope that isn't too simple . You've been watching too many quacks on you tube like Jason Fung .Calories in/out is the truth. Its true when you eat carbs your body produces insulin and your body can not burn stored bodyfat for fuel until the calories from those carbs are burned through and Insulin levels return to normal . Protein will also raise insulin levels . Fat does not spike insulin however FAT DOES NOT REQUIRE THE PRESENCE OF INSULIN TO BE STORED AS FAT, Ill say that again FAT DOES NOT REQUIRE THE PRESENCE OF INSULIN TO BE STORED AS FAT. So in effect the calories you ate from a high fat meal will also have to burned through before the body will go back to burning stored bodyfat , this is why if you overeat on keto YOU WILL gain weight  . This is why when calories are equated it makes no difference on a fatloss diet whether you go high carb or high fat
You do "burn" calories just by being alive. It might be trying to tell you your metabolic rate. How many calories you use a day. It's probably off a bit though
I am also finding them totally off! All my info is correct. I just bought the watch today and put it on after tea so been pretty chill / sat on the sofa etc and it says I’ve burned 5000 calories since 18:30 - 22:00 sitting on the sofa. It jumps up 30 to 60 calories every minute🥲
