Charge HR display brightness has gone low
ANSWERED
I have bought charge hr 3,4 years back , now gradually its brightness has gone low, and the display cannot be seen. Also the black stripes are visible..
So what can be done to?
1 BEST ANSWER
Accepted Solutions
Hi @Raw..smike  you can try a restart of the device, but since it's more than a few years old, it probably isn't going to get any better. I had the Alta HR and over time, it had the same dim screen beginning. The best thing is to check out the Fitbit sales coming up.
Stepping in the U.S.A. since September 2013. Android 14
3 REPLIES 3
Can we replace the battery? That would do it
Hi @Jaglenn  no, it wouldn't. The batteries in these devices is not replaceable. Only the retired Zip has a battery that can be replaced.
