07-17-2016
12:51
09:39
JuanJoFitbit
07-17-2016
12:51
09:39
JuanJoFitbit
Battery drains very fast. lights stay on constantly. after giving it a full charge, battery half dead afte 1 hour. bought it 6 months ago, first trouble i have had. Retarted it 6 times, as suggested in earlier posts, no help. any ideas?
07-26-2018 09:06
07-26-2018 09:06
I started having this problem last night. After going through the support, they told me to buy a new one. Since I am out of one year warranty (bought Charge 2 in Nov 2016), all they could give me was 25% discount for new purchase. Interestingly, this started happening after a software update on the Fitbit app. Not sure both of these are related.
12-20-2018 23:31
12-20-2018 23:31
Am having the exact same problem with a Fitbit Alta HR, like many replies the problem started just after the warranty expired. Disappointed to see this is a common problem, so obviously an inherent fault, but with no solution. This thread being marked as solved for a response that simply advises to contact support isn’t very helpful, especially since the common experience appears to be support advising ‘buy a new one’. I expect Fitbit’s reputation will suffer if this is such a common fault with no solution, says a lot about lack of quality and reliability.
Best Answer12-28-2018 10:20
12-28-2018 10:20
Best Answer12-29-2018 20:49
12-29-2018 20:49
Contacted customer support,and now a replacement is being sent. I have to say the customer support experience was pretty positive, both for the timely responses and of course the good outcome for me.
Best Answer04-21-2019 14:00
04-21-2019 14:00
Setting the Heart Rate under settings to AUTO from ON, worked for me. The green light goes OFF automatically when I don't wear it. It wakes up when there is a movement.
Best Answer08-14-2019 12:56
08-14-2019 12:56
This issue happened to my Charge 2. I was devastated, but decided to try something. I stuck it in a drawer for 3 weeks (so the lights constantly on didn't bother me). After about 3 weeks, the battery is totally discharged and I plugged it back in to charge. Yes!!!!! It worked. everything is good now, we'll see how long it lasts.
Best Answer01-07-2020 05:32
01-07-2020 05:32
just go to settings check heart rate option automatic. if it is not automatic make automatic.
Best Answer01-07-2020 05:51
01-07-2020 05:51
04-10-2020 11:47
04-10-2020 11:47
Green light stays on continuously. Bit won't work and runs battery down.
Best Answer05-13-2021 06:01
05-13-2021 06:01
HOLY SMOKES. I found the solution!!! This was driving me absolutely nuts. The green lights on the back were ON continuously. Did all the reset combinations suggested. Switched the heart monitor from "auto" to "on" to "off"... NOTHING!!! UNTIL I found this genius video on resetting to factory setting. GREEN LIGHTS TURNED OFF!!!! Simply follow these instructions. After you perform the sequence, let the fitbit charge HR sit for a few minutes. I can't believe that the customer service reps did not let anyone know about this!!! Here is the link to the video... https://www.youtube.com/watch?v=D8QigJQbuIo
