01-16-2019
05:37
20:07
01-16-2019
05:37
20:07
My sleep tracker won't work correctly. I'll be asleep until 8 am or later and it won't track sleep past 3 or 4am
Moderator edit: Updated title for clarity
01-17-2019 11:15
01-17-2019 11:15
Hey there @Pirates_fan1, welcome to the Fitbit Community Forums! 🙂
I'm very sorry to hear that you're having problems with your Charge HR not recording your sleep correctly. I'll be hhappy to help you out!
I can recommend checking the following tips to ensure that your tracker will record your whole sleep:
1. Give your Charge HR a quick restart. For this, plug the charging cable to any USB port or UL-certified USB wall charger and plug the other end to your Charge HR. Press and hold the button for 10-12 seconds until you see the Fitbit icon and the version number and release the button.
2. Make sure that your tracker is a little snug on your wrist when you're going to bed.
3. Make sure you're sleeping with your Charge HR on your non-dominant hand.
Hope you find this helpful. Let me know if you need anything else!
