01-04-2016
15:31
20:42
01-04-2016
15:31
20:42
I just got my Charge HR and I can't get the calls to vibrate like they are suppose to. I've read a couple things about how to do it and it seems connected correctly but yet doesn't work. Please help! Thanks
01-05-2016 13:15
01-05-2016 13:15
@Bellamommy Welcome to the Fitbit Community! Try to restart your Charge HR. That can actually help with this vibration problem. If that doesn't work, I recommend to disconnect the call notifications from your cellphone on the app and then re-connecting them.
Try that out and let me know how it goes! ![]()
Best Answer01-04-2017 08:45
01-04-2017 08:45
This has also happened to me - with neither calls or texts vibrating; it worked initially, but now has stopped working. Did the reset and no change.
Best Answer01-19-2017 12:21
01-19-2017 12:21
Mine is exactly the same. Worked initially but now won't & ive tried the suggested tips. Not sure what to do. May return as faulty....
Best Answer01-19-2017 13:16
01-19-2017 13:16
I fut
I figured out by accident that you can also turn off/on the vibrating from the device itself by pushing and holding the button...though this is not well documented - not sure why the help desk people did not suggest this as the problem. It is easy to accidently change the setting. Hope this helps you.
03-17-2017 09:41
03-17-2017 09:41
this solved my issue! thanks
05-26-2017 23:25
05-26-2017 23:25
Brilliant thanks
sonmuy. Worked
for me
Best Answer10-10-2017 16:36
10-10-2017 16:36
What button do I hold in? Mine stoppped vibrating when I get a call I can’t use my phone on the job which is the reason I bought this please help Thank you
Best Answer10-10-2017 18:15
10-10-2017 18:15
10-11-2017 03:46
10-11-2017 03:46
Best Answer10-11-2017 08:04
10-11-2017 08:04
None of the solutions has worked on my Fitbit hr. it still doesn't vibrate and tell me I have a call and I really need this function as I am deaf. Please help. It is the main reason I bought the Fitbit
10-11-2017 08:09
10-11-2017 08:09
Best Answer10-11-2017 12:39
10-11-2017 12:39
Best Answer10-16-2017 22:46
10-16-2017 22:46
Please can someone help me as my Fitbit is still not vibrating when I get a call. I am deaf and I need this function. I have tried all of the 3 ways mentioned before and it's still not working. I'm missing important calls HELP!
Best Answer10-17-2017 14:23
10-17-2017 14:23
@Chasesmommy I hope you're doing well! I'm very glad to hear that it is now working for you! Thanks for sharing the workaround that worked for you. I'm sure this will help other users as well.
@TezzaLynne Welcome to the Fitbit family! Thanks for trying all the workarounds provided. Just to get on page, can you tell me what kind of troubleshooting have you performed? Usually, the troubleshooting that helps is the following:
If you haven't done any of those, please try them out.
Keep me posted! ![]()
Best Answer06-02-2018 00:36
06-02-2018 00:36
Hi there,
It is not working, I tried all of these.. the maximum I got the notifications for one day after resting my charge HR !
There is an issue here need your attention!
Best Answer06-02-2018 06:20
06-02-2018 06:20
Best Answer06-02-2018 06:21
06-02-2018 06:21
Best Answer06-02-2018 06:31
06-02-2018 06:31
Dears,
I tried to check notifications by long press!
Tried reseting the Fitbit!
Tried to check no disturb!
Tried to encrypt, remove encryption..
Nothing worked!
In my opinion, this product not reliable as the last model!
In five days if still it is not fixed, I left with no option but to return
Best Answer06-02-2018 13:21
06-02-2018 13:21
N7ouli,
With the latest Fitbit update, it longer sends you notifications if your phone is on silent. Turn your phone's ringer to vibrate or louder to have it send notifications. Hope this helps.
