10-23-2016
18:40
12:11
LizzyFitbit
10-23-2016
18:40
12:11
LizzyFitbit
My fitbit won't charge at all I have tried all of the solutions what am I supposed to do
02-19-2019 04:29
02-19-2019 04:29
I’m having trouble with Fitbit charger3 The lite won’t come on but can feel vibration
Best Answer03-01-2019 00:07
03-01-2019 00:07
@AD_16 wrote:2 days after i received my 2nd fitbit (1st blaze lasted me 2+ years and i loved it), it abrumptly turned off. My fitbit won't charge (turn on, flash, show any sign that it's charging).
I've tried the following without success:
- cleaned the ports/battery contacts
- tried multiple different charging sources (wall outlet @110V & 220V, computer, portable power bank)
- put device in freezer for a week, then left out for another 9 weeks to see if the battery might need to drain completely before attempting to charge again in order to conduct reset (left button + bottom right).
- contacted Fitbit support and was told my case would be elevated and receive an email from Fitbit to continue troubleshooting options (haven't received email yet).
***UPDATE 1 MARCH 2019: ***
FITBIT SUPPORTED MY REQUEST AND SENT ME A NEW "PEBBLE" (AKA THE WATCH/COMPUTER, NO BAND). I'VE RECEIVED AND AM BACK UP AND RUNNING. I STILL DON'T KNOW WHY THE PREVIOUS DEVICE MALFUNCTIONED.
Best Answer03-01-2019 18:15
03-01-2019 18:15
Good for you!
Best Answer03-02-2019 07:47
03-02-2019 07:47
Best Answer03-04-2019 06:08
03-04-2019 06:08
My Fit bit Alta is just 4 months old.
Now it doesn’t get charged.
Can I find a place in Hyderabad to get it repaired.
Best Answer04-29-2019 09:50
04-29-2019 09:50
My Fitbit does not charge either. I just tried your recommendations. Still nothing. This was a Christmas gift this year.it quit not charging about a month ago. So fustrated.
Best Answer04-29-2019 23:06
04-29-2019 23:06
Best Answer04-29-2019 23:34
04-29-2019 23:34
Best Answer05-19-2019 23:22
05-19-2019 23:22
You are a genius. Thank you.
Best Answer05-22-2019 12:00
05-22-2019 12:00
These Fitbits are configured just like cell phones. They both stop charging or will not hold a charge long after about 3 years. Manufactures know exactly what they are doing when these items are manufactured. Its all about having to go and and buy a new one.My fitbit stop charging about 3 yrs in. I tried every solution under the sun and it still didn't work. My fitbit is now in the closet somewhere.
05-25-2019 05:00
05-25-2019 05:00
What button do you hold down? My Fitbit won’t charge and I tried and I can’t figure out what button.
Best Answer05-26-2019 11:58
05-26-2019 11:58
what button do you hold
07-05-2019 13:22
07-05-2019 13:22
my fitbit battery died, and upon attempting to charge it, it will not charge. i cleaned it and let it sit plugged in and nothing. please help.
Best Answer07-08-2019 05:46
07-08-2019 05:46
Thank you so much, SolangeE!
The toothbrush method for cleaning the charging contacts worked really well!
I no longer have to worry about purchasing a new Fitbit.
Best Answer07-10-2019 11:31
07-10-2019 11:31
Don't know if you ever got your Fitbit Charge 2 to charge again or not, but here is what worked for me that I didn't see in any posts on how to resolve. I had a spare charger that I kept at work in case I needed to charge the fitbit there. Since my Fitbit was no longer working and none of the suggestions worked, I brought it home, and on a whim tried it - and it worked - my Fitbit started charging and fully charged up. I tried hooking up the old charger (the one I kept at home), and nothing. So from this, I assumed that the CHARGER was the issue, not the Fitbit itself.
Best Answer09-27-2019 20:05
09-27-2019 20:05
Thank you so much with helping to get my Fitbit to charge.
Best Answer10-31-2019 09:36
10-31-2019 09:36
I have a Charge 2, roughly 3 years old. I’ve cleaned the terminals. I’m plugged into my computer. I’ve done the whole rest thing—still nothing. I do feel it buzz a couple of times and that green light is flickering, but nothing comes up on the screen.
Best Answer10-31-2019 09:39
10-31-2019 09:39
Autocorrect in action—I have done the hold the button down for 4 seconds, even 10, and nothing comes up on the screen...
Best Answer10-31-2019 09:45
10-31-2019 09:45
Best Answer10-31-2019 11:20
10-31-2019 11:20
