10-23-2016
18:40
12:11
LizzyFitbit
10-23-2016
18:40
12:11
LizzyFitbit
My fitbit won't charge at all I have tried all of the solutions what am I supposed to do
11-01-2019 14:35
11-01-2019 14:35
Why not replace the battery?
There are many sources and instruction on the net.
I got my new battery and tools for less than $9.
It was easy to replace.
11-01-2019
17:13
12:01
AlvaroFitbit
11-01-2019
17:13
12:01
AlvaroFitbit
The battery is ok—it’s fully charged and it logs activity. It’s just the screen is black so I can only see the activity on the app.
I did check out some of the kits, though, so thank you for that suggestion.
Moderator Edit: Personal info removed
11-02-2019 01:22
11-02-2019 01:22
Same problem. This is what you get when you manufacture in China on the cheap, I reckon.
11-10-2019 14:35
11-10-2019 14:35
Agreed. Made in China and does not work. My wife bought me a fitbit for my birthday in April 2018 and it stopped charging in August. It worked for about 3 months. It won't take a charge or turn on. Totally defective, garbage product. And the company won't let me return the watch to them. They will only give me a discount to buy a new watch. They have lost my business.
11-16-2019 12:32
11-16-2019 12:32
I have a Alta Fitbit I try charging it and I did everything to turn it on but it will not do anything so now what!
11-18-2019 09:08
11-18-2019 09:08
Ditto - same exact problem 😞
12-18-2019 23:57
12-18-2019 23:57
Same. I've had mine for about 2yrs. It shows the charging lights when hooked into charger but when I take it off all the lights turn off. I have the flex.😭
01-17-2020 03:03
01-17-2020 03:03
Fit Bit's are useless ! I have had two Fit Bits and two sets of Fit Bit scales. They have all broken! Total waste of money I recommend Garmin which are good quality
02-19-2020 15:47
02-19-2020 15:47
I have a brand new fitness tracker! Connected with USB port ,. No power at all!
02-19-2020 15:50
02-19-2020 15:50
Nothing! No V122.
03-19-2020 04:02
03-19-2020 04:02
Hello,
I have tried cleaning contacts, I have tried using my computer, I have tried different outlets...
I am so frustrated!
This charging format is way too temperamental!
03-19-2020 07:47
03-19-2020 07:47
I've switched to an iWatch--not the same, but at least it works. Loved the Fitbit until things went wrong, and then it just became disposable. Hopefully they will resolve the issues--and their customer service, which seems to be all over the spectrum from good to bad. Good luck, all!
03-20-2020 04:33
03-20-2020 04:33
03-20-2020 04:34
03-20-2020 04:34
03-22-2020 13:02
03-22-2020 13:02
I've tried all your suggestions and still no luck. Am I stuck with a dead unit?
03-22-2020 15:02
03-22-2020 15:02
03-22-2020 23:30
03-22-2020 23:30
03-22-2020 23:32
03-22-2020 23:32
04-24-2020 02:18
04-24-2020 02:18
Mine too , tried all kind of steps but no use ?
04-24-2020 06:17
04-24-2020 06:17
