Charge HR won't hold charge
I am finding that just recently my charge HR won't hold charge for any longer than a day if that. Has anyone else had this problem and how do i fix it?
1 REPLY 1
@Kimmiboo It's great to see you in the Community!
Let me help you with your Charge HR not holding a charge. Try cleaning the contacts using cotton swab with rubbing alcohol, then charge it by plugging it for a couple of hours directly to your computer's USB port (try different ports) or use an UL-certified USB adapter. You can follow these instructions to help improve the battery life.
Let me know how it goes.
Alvaro | Community Moderator
