01-23-2016
23:31
20:15
01-23-2016
23:31
20:15
02-25-2016 23:21 - edited 02-25-2016 23:21
@SeaweedSausage wrote:Just a shot in the dark, if people haven't fully removed their devices and turned off phones, made sure updates happened. Just try to run through the 9 steps I have listed in another thread (linked below). We are all getting tired of this constant sync issue. A couple people today already had some successful connects after following the directions.
https://community.fitbit.com/t5/Charge-HR/Tired-of-syncing-issues/m-p/1197197#M101897
Worked perfectly. Thanks.
Best Answer03-03-2016 00:20
03-03-2016 00:20
I have a problem too with time - and I'm using iPhone with the latest OS and fitbot dongle on the Mac... It's Fitbit that is the problem 😉
Best Answer03-03-2016 11:26
03-03-2016 11:26
I wish I had researched more prior to my purchase. I would have bought a garmin.
Best Answer03-03-2016 12:01
03-03-2016 12:01
Best Answer03-08-2016 09:21
03-08-2016 09:21
I have the same situation.
Best Answer03-08-2016 09:36
03-08-2016 09:36
Best Answer03-08-2016 21:38
03-08-2016 21:38
Best Answer03-08-2016 22:52
03-08-2016 22:52
I did that a couple of weeks ago. Just had to do it again ![]()
Best Answer03-08-2016 23:48
03-08-2016 23:49 - edited 03-08-2016 23:49
Do this...IT IS THE FIX :
Best Answer03-09-2016 00:27
03-09-2016 00:27
Tried returning and getting a new Charge HR before ending up with the same problems. Device doesn't sync and no amount of resetting or factory resetting even seems to fix it for me. Really disappointed, when it worked I was pretty happy with the device but at this point I'm so sick of dealing with it I doubt I'll try much longer before just returning it and going with some other tracker.
Best Answer03-09-2016 00:41
03-09-2016 00:41
Garmin are good but I had two fail within a year so swopped for the fitbit charge HR?! Not feeling overly impressed with this now not syncing.
Best Answer03-09-2016 01:29
03-09-2016 01:29
Best Answer03-15-2016 15:14
03-15-2016 15:14
Best Answer03-15-2016 17:05 - edited 03-15-2016 17:08
Did you see my solution...it works every time.
FACTORY RESET ... Ignore the stuff at the beginning of the article and just do it.
IT IS THE FIX :
03-17-2016 04:02 - edited 03-17-2016 04:04
Great this worked for me, factory reset and now everything is working as it should. Thanks.
Best Answer03-21-2016 09:01
03-21-2016 09:01
This worked!! I followed the steps and chose to set my device as a new one. I noticed that there was an update on the app which did the trick and hopefully will last the lifetime of the device without going back to the same problem. Like all the others, the solution was very elusive and to some even frustrating! I guess my patience paid off and thanks I came across to this post. Many thanks and hope this will further help others.
Best Answer03-21-2016 13:23
03-21-2016 13:23
Best Answer03-21-2016 13:40
03-21-2016 13:40
mine is starting to do this as well...I can get it to sync, but it is losing time and now it went back an hour...what the heck?
14:39
08:43
AlvaroFitbit
03-21-2016
14:39
08:43
AlvaroFitbit
I had the same problem with the time off by several hours. I turned on my Bluetooth, turned on my Iphone, opened the fitbit app on the phone, plugged my Charge into the charger. The phone and Charge did an automatic update and then synched. I now have the correct time on both.
Moderator edit: format
