08-13-2021 17:36
08-13-2021 17:36
Hi! I wanted to Message for help with my Fitbit hr. I’ve reset and factory reset the device, redownloaded the app and software multiple times, have everything up to date, redone my Bluetooth, and fully charged the hr but it’s not picking up anything 😞 I have a fully updated MacBook Air and iPhone 8 and both the app and software are the latest as well.
08-13-2021 19:21 - edited 08-13-2021 19:22
Ok @EliPurdy what is the problem?
Does your tracker sync it's data to the cloud?
Are you receiving notifications?
When you try, the now not fully supported Macbook, do you turn your phones Bluetooth off
08-13-2021 19:44
08-13-2021 19:44
Hi! I am not receiving notifications or any synching at all. With my mac, I have everything around it with Bluetooth off. Same with my phone when I tried synching it there. The tracker is on and can charge, but isn’t being picked up by any of my devices at all.
08-13-2021 20:35
08-13-2021 20:35
So you are saying that you have a sync issue @EliPurdy
Have you checked this doc?
One more step, that support suggests, others have found use full, but not mentioned in help, is to clear the fitbit apps cache.
