06-08-2020
22:49
17:01
06-08-2020
22:49
17:01
Hi,
has anyone had any issues when changing there band!?
My original bad has broken and seemingly it’s a quick click to change the band!
As soon as I opened the back it’s just fell to pieces!
The screen is no longer worked although the battery still seems to have life!
Anyone else having these issues?
06-13-2020 13:44
06-13-2020 13:44
Hello @Shivy86 , may I ask which Fitbit you have? The Charge, has a glued on band, it will need to be cut off and a repair kit with a replacement band gets glued on.
Best Answer06-15-2020 02:02
06-15-2020 02:02
It's the original fitbit.
I followed all the instructions and videos.
Unfortunately it fell apart and the screen is now bust.
RIP fitbit!
Thanks for coming back to me though.
Best Answer06-23-2020 09:25
06-23-2020 09:25
You mention that changing your band is a quick click, but then say that you have a Charge, with no heart rate.
This band is glued on and may need being cut off. It is not a simple band to switch.
