07-15-2016
05:54
17:01
07-15-2016
05:54
17:01
07-15-2016 06:19
07-15-2016 06:19
07-17-2016 06:56
07-17-2016 06:56
@Posies98 Welcome to our Community! Try cleaning your tracker's contact with a toothbrush or toothpick and then use cotton with rubbing alcohol to finish the process. After this restart your tracker by doing the following:
1.- Plug your charging cable into the USB port and insert the other end into the port on the back of your Fitbit Charge. Your Charge will begin charging.
2.- Press and hold the button for 10 to 12 seconds until you see the Fitbit icon and a version number (e.g. "V30").
3.- Let go of the button.
4.- Unplug your tracker from the charging cable.
Try doing the restart 3 times in a row.
Let me know how it goes!
09-13-2019 13:14
09-13-2019 13:14
it worked after doing it 3 times
