02-16-2018
04:53
17:01
02-16-2018
04:53
17:01
My charge shows a battery with an exclamation in it like its empty. It was just charged that morning. Now that battery picture is froze on my screen. Can't get it to do anything else, its just froze. Help
02-20-2018 08:23
02-20-2018 08:23
Hello @robinrainey, I hope you're doing well, it's nice to see you around! ![]()
Thanks for bringing this to my attention. Have you tried to reset your Charge lately? If so, the exclamation point on your tracker means the Charge started a firmware update but was unable to finish it. At this moment I would like to ask you to go to your phone Bluetooth settings and check if your tracker is on the list of paired devices. If it is, remove it and try to start the update again from the Fitbit app.
Now, if the exclamation point is still showing up, my best recommendation would be setting up your tracker as a new device as this will force the update to finish. Don't worry, none of your information will be deleted when you set up your Charge as a new device:
To set up your tracker:
I hope this can be helpful, give it a try and keep me posted in case you need anything else!
02-20-2018 09:55
02-20-2018 09:55
Best Answer02-21-2018 04:43
02-21-2018 04:43
Hello @robinrainey, I hope you're having a great day, thanks for taking the time to reply! ![]()
Congratulations on your Charge 2! I'm really glad you're in love with it, it's definitely a great tracker and I hope you enjoy it as much as I enjoy mine. ![]()
Please remember that if you come across any issue, please feel free to reply, I'll be happy to assist you.
Happy stepping!
Best Answer12-18-2019 16:32
12-18-2019 16:32
Hello,
I’ve had my Fitbit Charge 3 for a couple of months.
I’m getting the Battery with an Exclamation error. Tried unpairing, resetting adding as a new device still shows the error. In the Fitbit android app it sees the device and says battery empty. It doesn’t seem to want to charge with the error on the screen.
Any suggestions how to get past this error and get the device charging again?
Thanks!
Best Answer12-28-2019 21:24
12-28-2019 21:24
Hello
My Fitbit charger 2 is showing battery sign exclamation mark. I followed the instructions in this thread to set it up as new device. Now the app is requesting 4 digits pin to pair with the device. But the Fitbit still only shows battery exclamation. Where do I find the pin?
Thank you.
Best Answer12-28-2019 21:30
12-28-2019 21:30
My Fitbit seems to have paired with the app. The app says battery empty. Fitbit still shows exclamation mark and does not seem to charge battery. The app says the Fitbit has firmware version 22.22.58.0.
Is it still a firmware issue? How do I recover?
Best Answer08-16-2022 09:53
08-16-2022 09:53
I am having this problem as well. I got as far as step 4 where the app asks for a pin that should be showing up on the fitbit screen. All I can see is the battery icon with the exclamation point. What now?
